Steam big picture and duplicated displays - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-12-2013, 01:35 PM - Thread Starter
Bai Shen's Avatar
Anybody running big picture using a duplicated display? I ordered a gtx670 and I'm planning on duplicating my primary display to my tv. Just wondering if anyone else had tried it.
Bai Shen is offline
post #2 of 7 Old 03-15-2013, 12:55 AM
darklordjames's Avatar
Liked: 94
As long as both displays are the same resolution (1920x1080 as an example) it should be flawless. Duplication gets weird when resolution variances are in play.
darklordjames is offline
post #3 of 7 Old 03-15-2013, 01:34 AM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
Running it on 3 outputs and 6 displays, no issues.
Jason
Media Room = Vizio 4K 70" lcd/Denon x4100/Audiosource Amp 100/Klipsch speakers/Velodyne subs/Sony BDP s780/PS4 Pro/X1S/WiiU/PS3/360/Wii/Game PC/Multi-Arcade / #standwithscotty / My HT SLIDESHOW
DaGamePimp is offline
post #4 of 7 Old 03-16-2013, 11:37 AM - Thread Starter
Bai Shen's Avatar
Finally got my replacement card in and hooked it up. I can indeed run a duplicated main monitor setup with my tv. They're both 1080p. My secondary display is only 1680x1050.
However, I keep getting issues where the monitor setup is forgotten. It will rearrange my windows to different monitors and also change the resolutions. I'm not sure if it's a Big Picture issue or just Windows itself having issues.
Have y'all seen anything like that?
Bai Shen is offline
post #5 of 7 Old 03-18-2013, 08:11 AM - Thread Starter
Bai Shen's Avatar
Turns out that my issue is caused by the receiver turning on and off. Every time it changes state while the computer is on my monitor setup gets all jacked up. Windows get moved to the wrong monitor, resolutions change, etc.
Anyone else had this problem? Any suggestions for a solution?
Bai Shen is offline
post #6 of 7 Old 03-20-2013, 01:51 PM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
Check to see if your AVR has a stand-by pass through mode where it keeps the HDMI chain active when it is powered off, this will pull a bit more current but should solve your issue.
Usually you have to leave the HDMI selection on the one you wish to remain active when turning off the AVR but some AVR's allow you to assign the input that will pass through.
Jason
post #7 of 7 Old 03-20-2013, 02:17 PM - Thread Starter
Bai Shen's Avatar
Jason
I thought about that but haven't had a chance to check it.
Bai Shen is offline
Reply General Gaming Help
