need help building my first gaming rig - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-26-2013, 11:09 PM - Thread Starter
RenegadeCarter's Avatar
I'm fed up with consoles and would like to switch to pc but need some help building one. My budget is $ 500-600. I will be playing mostly star craft 2, dota 2, bf3, and crysis 3. Is it possible with my budget to play bf3 and crysis 3 on high settings with an fps over 30 ?. I already have a keyboard,,mouse, and monitor which would be my 40 inch 1080p lcd tv. I plan on buying my parts on newegg a day Frys electronics but I'm open to any other place too. I will need an network adapter btw. I'm such a noob and wo u ld greatly appreciate some words of wisdom from any pc gamer.
RenegadeCarter is offline
post #2 of 4 Old 03-28-2013, 10:06 AM
Mugenstylus1's Avatar
Spec PC
I just put this pc together now for you. It is a little higher then you price range, but look at it. and if there is stuff you can salvage from other things like hdd, and so on, price will go down.
Mugenstylus1 is offline
post #3 of 4 Old 03-28-2013, 12:38 PM
DaverJ's Avatar
Quoted: 1088 Post(s)
Liked: 3509
I would suggest posting in the HTPC section. Very few people venture in this "General Gaming Help" sub-category.
DaverJ is offline
post #4 of 4 Old 04-01-2013, 11:33 AM
failedjedi's Avatar
Do you have a microcenter near by? They often have great deals on cpu/board combos.
http://pcpartpicker.com/p/NIoE
It's $700, but you can easily cut $40 from the case I went with an expensive one. You could save another 15-30 on the power supply but I gave you a more future proof one you could reuse on your next build. Hard drive was just a guess, and a decent starting point to see price to storage ratio. Can save 90 on windows if you have a copy or a student and can get a copy cheap/free or know a student. You could save another $20 on the board if you go to a slightly worse board, and it may be worth saving the money considering it's a budget build. It's doable to get a decent enough rig in that price range. This is atleast a base outline to work off of. Plus if you have a microcenter you can save more buying the CPU and board there. So some minor tweaks and watching for sales or reuisng old parts can get you a decent mid range gaming rig in that price.
failedjedi is offline
Reply General Gaming Help
