Sega Saturn SCART RGB Component conversion color problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-01-2013, 03:26 PM - Thread Starter
eccoboy's Avatar
Recently purchased this: http://www.amazon.com/SPECIALTY-AV-SCART-Component-Converter-Genesis/dp/B004XSSDPO to connect a Sega Saturn via component. Image looks good but I can't get orange to look orange. I've adjusted the POTs in the converter and the closest I can get to orange is red orange. Pink is also more of a magenta but orange really isn't orange. Other colors look correct as far as I can tell.
The setup:
Japan NTSC Sega Saturn
Saturn RGB SCART cable
SCART converter box
component cables (from amazon)
Sony 27" WEGA CRT NTSC
I have an adapter that allows me to output composite from the Saturn SCART cable. When I connect this way, orange looks very orange, so I know that the Saturn as well as the RGB cable are putting out a proper orange color in the signal. So that means that the converter box may not be putting out the proper colors. Or I'm seeing what I'm supposed to see.
Since I don't know much about RGB, my question is this: does RBG output a differnt color palette than what I see through composite or S-video etc.? Or should I be seeing a solid orange color through RGB just as I would with composite?
eccoboy is offline
post #2 of 3 Old 08-12-2013, 07:29 PM
brentsg's Avatar
Quoted: 103 Post(s)
Liked: 170
Japan and Europe both use the same SCART connector for RGB, but they are not completely pin compatible. It is possible that you are using a cable/device that is designed with EU SCART in mind with a Saturn that needs Japan RGB 21 connector. It has been years since I've looked at the wiring but perhaps that drives your issue.
Pioneer ELITE PRO-720HD | Pioneer PDP-5010FD | Sony XBR-55X850B | LG OLED55E6P
OPPO BDP-103 | OPPO UDP-203 | Toshiba HD-XA2
PlayStation 4 Pro | Xbox One S
brentsg is offline
post #3 of 3 Old 08-12-2013, 08:43 PM - Thread Starter
eccoboy's Avatar
Thanks for the suggestion, but I replaced the converter with a new one and everything looks great so it was simply a defective converter. Problem solved. Thread can be closed.
eccoboy is offline
Reply General Gaming Help
