Help me get 5.1Ch from my ps3 :0 PLease - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-09-2013, 08:35 PM - Thread Starter
newkidd's Avatar
Hi
I wanting to get my old home theatre system Philips DVD HTS3548:
(http://download.p4c.philips.com/files/h/hts3548_98/hts3548_98_pss_aensa.pdf)
Hooked up to my Ps3(through the Optical cable) for 5.1Ch sound, and since the DVD/Av box only has COAXIAL input will I need to get on of these?
(http://www.trademe.co.nz/Browse/Listing.aspx?id=636004748)
I'm just really confused if/how it will work once the I run DIGITAL COAXIAL CABLE from that SPDIF Decoder back into the COAXIAL Input (hts3548) as its only connected to my TV though RCA audio cable at the moment.
I think I'd rather be sure that my old Philips DVD/HTS3548 is still capable of 5.1 sound just so I don't waste the $100 on the SPDIF Decoder where I could be putting it towards a new theatre system.
Thanks for your advice
newkidd is offline
post #2 of 2 Old 09-12-2013, 08:51 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
All you should need is this:
http://www.monoprice.com/products/product.asp?seq=1&format=2&p_id=2948&CAWELAID
And an optical cable and RCA cable, of course.
Steam/PSN/Xbox Live: Darius510
bd2003 is offline
Reply General Gaming Help
Tomb Raider Ps3
