21:9 monitor for gaming? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-04-2014, 08:12 AM - Thread Starter
jake51's Avatar
Quoted: 106 Post(s)
I'm interested in this: http://www.lg.com/uk/monitors/lg-34UM65-P
It's huge and gaming could look really good on this
But is the black level good enough for gaming?
I would really appreciate comments from owners of this monitor
jake51 is offline
post #2 of 9 Old 08-06-2014, 06:29 AM
imeem's Avatar
would u be gaming on pc or on console? Because i know that some (or all) 21:9 monitors when used with consoles, you will have black bars because it's not running at the native resolution and the same aspect ratio.
imeem is offline
post #3 of 9 Old 08-06-2014, 07:14 AM - Thread Starter
jake51's Avatar
Quoted: 106 Post(s)
PC
jake51 is offline
post #4 of 9 Old 09-02-2014, 02:03 PM
Hoffmannyon's Avatar
Liked: 0
I think it may be big wide scale monitor. I like it. I am playing good with large wide scale screen...
Hoffmannyon is offline
post #5 of 9 Old 09-02-2014, 09:30 PM
aftcomet's Avatar
Quoted: 53 Post(s)
Do you have to horsepower to drive 2560 x 1080? In my opinion, if you're not going to running at least high, you won't be getting the most value out of your purchase.
But for the price of this monitor or less, I'd still recommend getting a 27"+ 120Hz 1440p monitor. I think the pure fluidity and ultra crisp image will prove more pleasing that pure width.
Here is a pretty good review:
https://pcmonitors.info/articles/the...80-experience/
aftcomet is offline
post #6 of 9 Old 12-07-2014, 09:55 PM
Liked: 1
I've been looking into getting a 21:9 monitor for a bit and it definitely seems like a lot of games support them well but like aftcomet, you need some horsepower. wsgf.org has a ton of info on what games work and dont work.
There is also a AOC brand monitor that is a bit cheaper and has great reviews, thats the one ive been eyeing.
evilpaul is offline
post #7 of 9 Old 12-07-2014, 09:58 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
I had a 29 incher and it was weird playing games on it....everything looked kind of stretched and squished.
See if you can see one locally in person before you spend money on one.
NODES is offline
post #8 of 9 Old 07-19-2015, 04:39 PM
Quoted: 59 Post(s)
Liked: 4
Had a Dell 3415W 21:9 screen for a while. Amazing monitor but not many games have native support for it. With every new game that fails to support the res people have to w resort to wsgf forums for a solution. Great guys there doing something the developers should have done in the first palce!
Yiorgos759 is offline
post #9 of 9 Old 03-01-2016, 04:31 PM
hatlesschimp's Avatar
Quoted: 482 Post(s)
Liked: 507
Get a LG 34uc97 its amazing. Ive never had an issue playing games on it. Plus its curved that helps.
hatlesschimp is offline
Reply General Gaming Help
