If you can add to the list of games using a particular engine or know another game or engine that allows setting native resolution, either post a follow-up to this e-mail or PM me and I will try to put together a list.
Typically, given your examples, a machine reboot might be a sign of video card overheating. At least that's what I've found in the past. Could also simply be a bad vidboard...
In some cases, the built-in menus are hardcoded or otherwise don't accept weird screen sizes. So you can pre-set in preferences/config file, and it may run with it.
In some cases, yes, it'll show it as the current resolution. Of course, once you switch resolutions, your custom one will disappear.
Lastly, in some cases, the game is completely hardcoded to only accept a handful of resolutions, and won't accept even forced values in cfg.
well according to what i have read, let's take Call of duty as one example. I attempted to alter the cfg files but the menu still shows a res of 800x600 and it looks like 800x600.
Now DOOM3 seems to remain with the same number yet it looks like the resolution I have altered it to.
Guild Wars is having an open beta event this weekend. Game natively supports 1280x720x60Hz from the ingame menu, it defaulted to 1024x768 before I could make the change, looks and runs great.
Everquest 2 supports 1280x720 via an .ini hack. Tribes:Vengeance supports it, iirc I had to .ini hack that, too. Rome:Total War natively supports 1280x720 in the battle screen (3d) but not the campaign screens (2d).
Originally posted by GKMad Medal of Honor: Pacific Assault Demo.
It's widescreen if you edit the config file and put in a custom resolution - note there are several areas to make res changes. I only did it to the gameplay part and it worked and looks 16:9 with the correct aspect ratio.
Just as a note, the full version of the game supports widescreen resolutions.
Anyone have a tip for changing Star Wars Battlefront?
Originally posted by Dean Martin Just as a note, the full version of the game supports widescreen resolutions.
I've tried everything I can think of, but it's still a no-go. Hell, they're on their third patch and still haven't implemented yet. The other LucasArts games were easy to configure.
Anyone figgured out Need for Speed Underground 2? Does the hack from the first one work for the new one as well?
Gotta play this on my tv
Edit, I tried the old patcher, says it can only patch speed.exe so i rename d the exe to speed.exe and it says that it will not work, need a new patcher.
1280x720 is a natively supported res for Half Life 2. I have it up on my projector and it looks great. You just have to select widescreen in the options/video screen to have the widescreen resolution appear for selection.
I could'nt get Halflife 2 to startup when hooked up to my Viewsonic N2700w, (No video signal detected), until I hooked up my standard CRT and then went into the game options and changed to 16.9 1280x720, then hooked back up to the Viewsonic. The game looks beautiful!
Originally posted by powerstroke I could'nt get Halflife 2 to startup when hooked up to my Viewsonic N2700w, (No video signal detected), until I hooked up my standard CRT and then went into the game options and changed to 16.9 1280x720, then hooked back up to the Viewsonic. The game looks beautiful!
I ran into the same problem when trying to connect it to my sammy DLP, and had to do the exact same thing. It came up with some really weird resolutions, but it finally let me set it to 1280x720 and then it started up just fine.
Originally posted by turls Hitman 2 is a no-go I guess? From the same company and the same basic .ini as Freedom Fighters (which will do 1280x720), but if I change the .ini on Hitman 2 it chokes and won't start asking me to change color depth or resolution.
for hitman 2 change your desktop to the desired resoultion anf then edit the .ini file and set windowed (or is it window) from 0 to 1
i tryed the hack from widescreengaming forum for KOTOR and it works but not great, as you can see, parts of the HUD are gone. but it's widescreen http://tinypic.com/u4u8y
I have notebook with widescreen and I was wondering if there is any possibility to play Baldur's Gate (Shadows of Amn + Throne of Bhaal) in resolution 1280x800 or similar (maybe 1280x720)?
Just got done trying out the Star Wars Republic Commando demo. It doesn't support widescreen resolutions in the game menus, but you can force it.
Start the game the first time and setup your video settings, well, everything except the resolution. Then exit the game.
Then edit the file "Gamedata/Save/System.ini" and change the resolution for ALL settings in the file to what you want.
It'll have resolutions for LOW/MEDIUM/HIGH/VERY HIGH settings, and even though I had VERY HIGH selected in the game and changed the resolution for VERY HIGH, it wouldn't work. So I went back and changed it for every setting and it worked like a champ.
According to TigerDave's web site you can make the CoD demos go widescreen by editing the config.cfg file. However, I cannot find this file in the full game. I'm stumped.
Can you elaborate? Do you actually have a full copy of CoD?
I did look in the main folder for CoD and the was no .cfg file. In fact, I ran a scan of my entire hard drive and examined every .cfg file for my entire computer and could not find one associated with CoD.
Could my .cfg file be hidden somehow?
Status
Not open for further replies.
You have insufficient privileges to reply here.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
