Need help with a configuration - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-13-2006, 07:24 PM - Thread Starter
mp77's Avatar
Long story short I recent got the Sony 46" XBR2 and it only has two component inputs. This is where it gets tricky from a configuration standpoint. I can hook up everything I want (Xbox, Xbox 360, PS2, Wii, and DVD player) through my receiver and switch to account for the inputs. The potential problem arises when it comes to configuring the inputs. I love the settings that petmic10 gave and want to use them as much as possible.
After all that my question comes down to this. Which configuration would you go with? Note: I don't currently have the VGA cable for my Xbox 360 but would get it if it seemed like the right way to go.
A
Component 1 - DVD Player
Component 2 - Video Game Systems (Xbox, Xbox 360, PS2, and Wii) all using the setting I'm using for my 360
B
Component 1 - Xbox 360
Component 2 - DVD Player & remaining systems
C
VGA - Xbox 360
Component 2 - Remaining video game systems
I hope that was clear and any insight or advice would be appreciated.
mp77 is offline
post #2 of 2 Old 12-13-2006, 07:33 PM
Tyrant's Avatar
If you find yourself constantly tweaking your monitor settings for a specific console or the DVD player, you may as well single it out and give whichever device it is main priority. Of course, the optimal solution would be to give each device it's own discrete input, so option C would probably be the most convenient of the three.
Tyrant is offline
Closed Thread General Gaming Help
