Component Cable extenders - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-20-2006, 08:37 PM - Thread Starter
zero83's Avatar
O just got the Wii component cables, but they wonbt reach my TV, or my reciever where I have it positioned. If I buy a few RCA couplers, then another Male to male component cable, will I get any signal degredation. I jsut want to be able to extend the reach of the wii component cables
zero83 is offline
post #2 of 5 Old 12-20-2006, 09:05 PM
cavu's Avatar
Couplers are always a weak link!
You can get some excellent 25' component/audio cables for about $12 from Monoprice - cheaper than buying couplers, etc.! Monoprice has lengths from 6-50ft.
"The greatest obstacle to discovery is not ignorance  it is the illusion of knowledge." - Daniel Boorstin
"Our lives begin to end the day we become silent about things that matter.
" - MLK
cavu is offline
post #3 of 5 Old 12-20-2006, 09:10 PM
cavu's Avatar
You can get some excellent 25' component+audio cables for about $12 from Monoprice - cheaper than buying couplers, etc.! Monoprice has lengths from 3-50ft.
" - MLK
cavu is offline
post #4 of 5 Old 12-21-2006, 06:41 AM
Schmev's Avatar
OK, unless I'm missing something, you're telling Zero83 that couplers suck and not to use them, but then basically to buy another set of cables and extend the Wii cables? I'm not seeing any alternative Wii cables on that page.
Zero83, just get a set of couplers for the cable and add on. I can't think of any other option other than chopping the Wii cable ends off soldering/splicing some more lengths on. I think the picture quality will be just fine with couplers. I don't think I'd notice any difference on my 42w2 LCD, and I'm picky enough as it is, especially at only 480p.
Have you checked the other cable brands? I've heard some are longer than the Nintendo branded ones.
Schmev is offline
post #5 of 5 Old 12-21-2006, 01:43 PM
Brown Radagast's Avatar
You should be fine with just using regular coax + RCA couplers, unless you have a super long run. You'll even save some money.
Have fun with the WII! My nephews have already finished all of the games they got, LOL!
MY DILEMMA: New car or PJ? New car or PJ? New car or PJ?
Brown Radagast is offline
Closed Thread General Gaming Help
