30" Apple LCD, any way to play Xbox 360 or PS3 on it? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 12-21-2006, 04:50 PM - Thread Starter
flypenfly's Avatar
It has a dual link DVI connection only.
Is there any way to get the VGA out or the other outputs on it at good quality onto the Apple 30" LCD?
I was thinking of maybe some component break out box but I would really prefer to use the VGA out on the 360.
I don't think you can use the simple $2 DVI to VGA adapters since the cable on the Apple 30" LCD is dual link and doesn't accept an analogue signal.
flypenfly is offline
Closed Thread General Gaming Help
