Is it worth it for me to get an HDTV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-05-2007, 03:12 PM - Thread Starter
covert7's Avatar
Hey guys, I'm new here obviously and was recommended to come here for good advice. Here's my situation:
I was thinking about upgrading my TV as I currently have a Sony WEGA 37" CRT. It's a decent TV but stupid big n' heavy and showing its age a bit. All that we use it for now is to play our Nintendo Wii and to play PS2 games on. We also watch regular DVD's on it. We don't watch TV (cable or satellite.)
So as you can see, nothing we do involves High Def stuff at this time. I have no issues paying for an HDTV but from what I understand if I buy a nice LCD TV that does 1080p, the picture quality from these non-hd sources will potentially look worse than they would on a SDTV. So my two questions are:
1)Is that a correct assumption?
2)Would you buy a new tv given the above considerations?
I guess I just want a new TV hoping I get a better picture and something that doesn't take up nearly so much room. Thanks for any help and insight you can provide!
covert7 is offline
post #2 of 4 Old 01-07-2007, 09:15 AM
booloo's Avatar
Quoted: 24 Post(s)
For the most part, that is correct.
Nope. Considering the Wii highest level of picture quality is 480p, and PS2 only has a handful of games utilizing 480p, I would say wait until you are playing enough HD-enabled material to warrant a purchase.
booloo is offline
post #3 of 4 Old 01-07-2007, 04:11 PM
oktoberrust11's Avatar
Quoted: 69 Post(s)
Liked: 38
1.) For the most part, yes. Ensuring your potentially new TV to output SD material as a 4:3 image will help, but in general it may look worse.
2.) Depends on what you plan on doing in the future. Any interest in getting HD service? DVD's will certainly look better on an HDTV. Plan on getting a 360? PS3? HD-DVD/Blu-Ray player? If yes to any of these, I would take a gander. You should be able to pick up a ~40" 1080p LCD for around $2K.
IMHO.
Matt
Xbox Live: oktober rust | Mii: 5207 2388 9861 4135 | Steam ID: detroit820 | Origin ID: oktoberrust11
oktoberrust11 is offline
post #4 of 4 Old 01-08-2007, 12:58 AM - Thread Starter
covert7's Avatar
Thanks for the input guys. I think I've decided not to get an HDTV at this time. I cannot foresee us doing anything that will use real HD stuff, so I guess I'll just wait until some distant time in the future where we actually will have some stuff that uses it. Again, thanks for the input!
covert7 is offline
Reply General Gaming Help
