Audio question for gaming setup, need some advice pretty please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-10-2007, 09:38 AM - Thread Starter
Pratt75's Avatar
Hello everyone, I have a small audio problem at the moment. I have PS3 and a 360 hooked up to a lcd tv which I also use as as my pc monitor. I have my 360's audio hooked up to my pcs sound card. It works great. I tried hooking up my PS3's audio cables to the same pc card via a splitter. When I do this I get zero audio when both are plugged in. If I unplug either one, the other systems audio works just fine.
So is ther any way to have both audio outputs hooked to my pcs sound card at the same time or will I have to just keep having only one hooked up at a time?
Pratt75 is offline
Reply General Gaming Help
