SCART to Component Video? - AVS Forum | Home Theater Discussions And Reviews
Old 05-09-2007, 05:28 PM - Thread Starter
Richter X's Avatar
I have quite a few old game consoles (SNES, Sega Genesis, Playstation, etc.) that can output RGB natively. Unfortunately, my TV, a Sanyo DS24425, can only take Component Video as its highest quality input (unless you can somehow make it use RGB in the service menu).
Since you can buy SCART cables for these consoles on the market for fairly cheap, and saving me the trouble of making custom cables, I was wondering if there were any convertors out there that could turn the SCART RGB signal into Component Video and Stereo Audio. I've seen convertors online, but none of them have stereo audio output as well as the Component Video ports.
Richter X is offline
Old 06-08-2007, 12:12 PM
DarkSuperman's Avatar
Have you found a solution for this yet? I want to do the exact same thing but have only read about solutions that require soldering skills. While I probably could figure out how to do it, unfortunately I don't have the time (or the patience to deal with possibly messing it up). An all in one would be ideal.
DarkSuperman is offline
