Component video splitter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-18-2007, 09:55 AM - Thread Starter
zero83's Avatar
Hi there.
I have a question and need some big help.
I was wondering if there is such a device that will let me hook up my wii, and 360 to a single component video input. Onviously using only one at a time. I was looking at this
3 x RGB Component Video Splitter(@ amazon.com)
If this wont work. Can someone please post any experiences with the Pelecan system selector pro 2.0. I have been reading hooror stories about it randomly dying, and totally destroying picture quality. I ahve also heard about it randomly blacking out and loosing signal.
Any t houghts on this would be appreciated.
thanks
Zero
zero83 is offline
post #2 of 6 Old 07-18-2007, 10:43 AM
oktoberrust11's Avatar
Quoted: 69 Post(s)
Liked: 38
http://www.digitalconnection.com/pro...ideo/1154a.asp
The Audio Authority 1154A is a video and audio automatic switcher that I and others have had great success with. Depends on how much you want to spend.
Xbox Live: oktober rust | Mii: 5207 2388 9861 4135 | Steam ID: detroit820 | Origin ID: oktoberrust11
oktoberrust11 is offline
post #3 of 6 Old 07-24-2007, 01:20 PM
boneycat's Avatar
Zero, I'm not sure which one you are referring to at amazon, but you can find a bunch on ebay. I'm looking there myself. The one oktoberrust linked to is nice, but I'm not going to drop over 200 bones on one game part.
boneycat is offline
post #4 of 6 Old 07-27-2007, 07:51 AM
RyokoYaksa's Avatar
Don't confuse "switcher" with "splitter." They serve completely opposite purposes, and you want a component video "switcher."
I just use an RCA brand switcher and it works just fine. Works with a remote control, even.
RyokoYaksa is offline
post #5 of 6 Old 07-31-2007, 02:26 PM
boneless6220's Avatar
boneless6220 is offline
post #6 of 6 Old 08-07-2007, 08:36 AM
JTP
JTP's Avatar
I just hooked up all my systems to my Onkyo reciever and it works great. Its was a great solution for me.
Display: Samsung 4065F
Sound: Onkyo 504
4 Athena B1.2
1 Athena C1-1
AS P300 Sub
JTP is offline
Reply General Gaming Help
