Quality VGA switch - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-11-2007, 05:32 AM - Thread Starter
jdmioshima's Avatar
I was wondering if anyone could recommend an affordable vga switch box with as little video quality degradation as possible.
My Xbox 360 and Xrgb-3 share the same input on my monitor and honestly I'm just tired of them switching back and forth.
360 runs in 1280 x 720 or 1280 x 1024
xrgb runs in 1600 x 1200 or 1280 x 1024
jdmioshima is offline
post #2 of 4 Old 09-11-2007, 10:38 AM
indecision's Avatar
I am looking for the same info. I know you can't go wrong with the Extron line but not so affordable. I would love to have something with at least 2 inputs and dual monitor outputs would be even better.
indecision is offline
post #3 of 4 Old 09-14-2007, 09:43 PM - Thread Starter
jdmioshima's Avatar
Anyone? What about something from monoprice?
post #4 of 4 Old 09-15-2007, 05:47 AM
CyberScott's Avatar
Quoted: 106 Post(s)
Liked: 131
I've been using the Trulink 2-Port UXGA Monitor Switcher/Extender which I got at yourcablehookup.com. Works great for switching between my XBOX 360 and PC. The switch also comes with a remote for the lazy. You might need to pick up gender changers for the vga cables if you don't have them. I know the official Microsoft vga cable had one in their box.
My tv is a Samsung HRT-6168w which accepts a 1080p vga signal. I've discovered that if I don't use UXGA rated cables and switch connected from my pc to the tv, I could not get 1080p resolution to work from my pc. Every resolution below it would work. The UXGA cable and switch are rated for 1080p.
Hope this helps!
Samsung UN65HU9000FXZA (TS01) with SEK-3500U/ZA Evolution Kit
Onkyo TX-RZ1100 rocking 7.2.4 Atmos goodness!
LG OLED55C6P
Denon AVR-X6300H also rocking 7.2.4 Atmos goodness!
CyberScott is offline
Reply General Gaming Help
