Optical to Coaxial - AVS Forum | Home Theater Discussions And Reviews
Old 12-22-2007, 11:57 PM - Thread Starter
Strike Eagle's Avatar
Is there such thing as an Optical Audio to Coaxial Audio Cable Adapter? I want to connect my PS3 (which has optical audio out) to the speakers that I want (which have a coaxial audio input). Also, what would be better for my PS3?-A Durabrand HT400 5.1 channel surround sound system using a digital audio connection or a Logitech X540 5.1 channel surround system using a stereo audio connection?
Strike Eagle is offline
Old 12-23-2007, 12:03 AM
confidenceman's Avatar
Liked: 37
By "speakers" do you mean "receiver"? Without some sort of amplification, your speakers won't do you any good. Yes, you can convert the two signals, but you might actually be better off going with an RCA connection.
EDIT: Just missed your edit. Looks like you're going for a sub-routed 5.1 system. Again, though, I think those only do matrixed surround anyhow, so just stick with the RCA connections (if those systems have them). Personally, I'd go with a cheap HTiB ("home theater in a box") setup that includes a stand-alone receiver rather than one of those sub-routed systems. Nearly any 5.1 HTiB system with a stand-alone receiver will include at least optical.
PSN & XBL ID: drop me a private message
confidenceman is offline
Old 12-23-2007, 12:51 AM
cavu's Avatar
Monoprice has one for under $12 ...
"The greatest obstacle to discovery is not ignorance  it is the illusion of knowledge." - Daniel Boorstin
"Our lives begin to end the day we become silent about things that matter.
" - MLK
cavu is offline
Old 12-23-2007, 11:41 AM
RGoldberg's Avatar
I have that Monoprice adapter and it works great.
RGoldberg is offline
Old 12-23-2007, 09:50 PM - Thread Starter
Thanks. Now I want to know which connection is better for audio-Digital or Stereo?
Old 12-23-2007, 10:22 PM
Liked: 37
I'm guessing you mean "digital or analog." Simple answer: digital.
Old 12-24-2007, 02:59 PM - Thread Starter
Okay, I think the last thing I need to know is-Can I trust the "Durabrand" brand of products?
Old 12-24-2007, 03:10 PM
Liked: 37
I believe it's Wal-mart's own brand of electronics. If you trust Wal-mart, then you can trust Durabrand.
Old 12-24-2007, 10:55 PM
bkchurch's Avatar
And if you trust Wal-Mart: LOL!
bkchurch is offline
