Mitsubishi HD1000U, Denon 2307ci, Wii -- I can't get it to work - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-31-2007, 11:04 AM - Thread Starter
dbodarky's Avatar
I have a Mitsubishi HD1000U, a Denon 2307ci receiver and a Wii. I just bought the Wii and I cannot get the Wii to work over the single HDMI output to the projector. I purchased component cables and set the video set up but still nothing.
Can anyone help?
dbodarky is offline
post #2 of 2 Old 12-15-2008, 05:55 PM
peepoop's Avatar
I have a Wii and the same receiver, and it works for me.
The only thing I can think of is that you make sure you enable "Analog to HDMI convert." See page 54 of the manual.
Failing that, the problem may be your TV. I have a Panasonic plasma, and that's the only thing different between the two of us.
peepoop is offline
Reply General Gaming Help
