looking to use PC monitor for gaming TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-09-2008, 08:18 PM - Thread Starter
parapeligicdrumr's Avatar
hi i am looking to use a LCD computer monitor with only the VGA input for hooking up my PS3. Are there any less pricey alternatives to convert the RCA signal to a VGA signal?
i looked around and found the AverMedia TVbox 9 as a possible solution. however, its way out of my budget and im wondering if there are cheaper alternatives to get to the final result?
thanks
parapeligicdrumr is offline
post #2 of 2 Old 01-09-2008, 09:24 PM
bkchurch's Avatar
Google X2VGA
bkchurch is offline
Reply General Gaming Help
