Any way to integrate Wii to a switch? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-28-2009, 11:34 PM - Thread Starter
qposner's Avatar
I am thinking about buying a Wii for downstairs. However, I want to integrate it into a switch with my D* HR21 and DVD player. Either of these can run hdmi or component. I know I cant run the Wii through a swithc with the hdmi cables from the HR21 or dvd. What about component cables with the HR21 or dvd? The problem appears to be that I would also want audio to switch and the Wii does not offer digital audio through an optical cable. Any suggestions for me? I want to keep the system simple for my wife. Thanks!
qposner is offline
post #2 of 6 Old 12-29-2009, 08:22 AM
oktoberrust11's Avatar
Quoted: 69 Post(s)
Liked: 38
So you have TV upstairs with a video switch for the D* receiver and DVD player, correct? And you are putting a Wii downstairs hooked up to a different TV? I don't think I'm following; why do you want to integrate it to the video switch upstairs?
Xbox Live: oktober rust | Mii: 5207 2388 9861 4135 | Steam ID: detroit820 | Origin ID: oktoberrust11
oktoberrust11 is offline
post #3 of 6 Old 12-29-2009, 08:47 AM - Thread Starter
qposner's Avatar
Sorry if I was not clear. Forget about upstairs. Don't know why I said HR21 since that is upstairs.
Downstairs I have a Panasonic th37px60u plasma with a D* HR20 and dvd. I want to add a Wii and soundbar for wife/kids and want switching between components to be easy (one location instead of at the tv and the audio source). The problem is the Wii does not support hdmi and if I go all component cables (with HR20, dvd and Wii), the Wii will not support audio switching since it does not have digital audio (toslink). Any suggestion for how I can easily run these 3 components through 1 switch?
qposner is offline
post #4 of 6 Old 12-29-2009, 09:08 AM
Quoted: 69 Post(s)
Liked: 38
A Harmony remote?
The Audio Authority AA1154A component switch I have (http://www.copperbox.com/Audio-Autho...ch-p/1154a.htm) switches both toslink/coax digital audio and analog audio. I'm sure there are less expensive switches that do the same, but I can't recommend one.
post #5 of 6 Old 12-29-2009, 09:39 AM - Thread Starter
qposner's Avatar
A Harmony remote?
So I could run component video from all 3 sources, toslink audio from the dvd and HR20 and analog (red/white composite cables) audio from the Wii? It would then switch between all 3 for video and audio?
qposner is offline
post #6 of 6 Old 12-29-2009, 10:45 AM
Quoted: 69 Post(s)
Liked: 38
I don't know how it handles the digital/analog audio issue. Say you have both a Toslink and analog audio cables from the switch to your receiver (or is it right to the TV?); if you switch to the Wii inputs, does it know to send the audio over the analogs and not the Toslink? I honestly don't know..
Reply Nintendo
