does anyone make a shorter component cable... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-10-2010, 02:50 AM - Thread Starter
ceniack's Avatar
I have the official Nintendo component cable and it is about 8ft long. My tv is wall mounted and i have an Omnimount wall mounted shelf that you can use to hide the wires.
I recently purchased a new TV and am trying to clean up the wiring a bit while i am in there (separate the A/V wires from the power wires, etc...) and am in need of a shorter component cable (2-3ft if possible) so i don't have 8ft of cable wound up behind my components.
Has anyone ran into a similar problem and if so how did you overcome it? Any way to modify the existing cables to a shorter length without a loss in picture quality?
ceniack is offline
post #2 of 3 Old 01-11-2010, 09:58 AM
voodoozen's Avatar
Liked: 46
6' is about the shortest I've ever seen. You could always clip off a longer one and solder on new tips
voodoozen is offline
post #3 of 3 Old 01-11-2010, 01:56 PM
darklordjames's Avatar
Liked: 94
Or open it up on the connector side and cut'n'solder the connections there.
darklordjames is offline
Reply Nintendo
