Nyko Nunchuk compatibility - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-13-2010, 12:52 PM - Thread Starter
moothemagiccow's Avatar
I noticed a pretty good deal - Nyko sells a classic controller and nunchuk for $20 in one box. I really want the nunchuk so I can play Wii Sports Resort with a friend - is it compatible with the Motion Plus?
WiiU: moothemagiccow
PSN: moothemagiccow (duh)
moothemagiccow is offline
post #2 of 4 Old 02-13-2010, 02:42 PM
jwebb1970's Avatar
Liked: 38
If it's the wired Kama nunchuk, then yes, I believe so. IF the wireless Kama, then from what I have read - no.
Money does not buy happiness. It can, however, buy you a giant boat that you can pull up alongside happiness. - David Lee Roth
jwebb1970 is offline
post #3 of 4 Old 02-13-2010, 03:26 PM - Thread Starter
I knew I forgot to mention something! Yes it is the wired version. Thank you.
post #4 of 4 Old 02-13-2010, 04:01 PM
jwebb1970's Avatar
Liked: 38
you should be good to go, then.
Reply Nintendo
