Nyko Charge Station - AVS Forum | Home Theater Discussions And Reviews
Old 03-21-2010, 09:38 AM - Thread Starter
bodean's Avatar
Quoted: 173 Post(s)
Liked: 43
Using this:
http://www.amazon.com/Wii-Charge-Sta.../dp/B000LFJNF2
Seems one of my batteries no longer charges / holds a charge. it's about 2 years old, this charger station/batteries. Do they die out after a while? If so, any recommendations for good charging unit / recharger for wii?
Sony KDL65W850A 65" LED HDTV  || Bose Soundtouch 130 soundbar || Synology DS716+ NAS || XBOX One ||
Xbox Live : BoDEAN
bodean is online now
Old 03-21-2010, 09:58 AM
tdogroeder's Avatar
Quoted: 41 Post(s)
Liked: 81
I have the nyko charging unit and one of the batteries died within a couple months, and the other one does not hold a charge like it use to, to me it was not worth it I regret purchasing it since I already own plenty of rechargeable ones. So, I suggest buying rechargeable AA's, they will last you longer than the nyko ones, and you can replace on the fly as you need them and not have to charge the whole controller like the nyko system.
John 14:6 & John 3:16
Yamaha RXV765 & Emotiva LPA-1
Ascend Sierra-2s(LCR), RSS300, Polk R15, SVS PB12 plus
Panasonic S65, Sony S5100, PS4, PS3, XBOX 360
tdogroeder is offline
Old 03-21-2010, 11:10 AM
jhoff80's Avatar
Quoted: 389 Post(s)
Liked: 347
Yeah, rechargeable batteries just die out after (hopefully) a while.
My first Wii recharger's batteries were dying out, so when I saw a good deal on the MadCatz one I have now, I got it. Unfortunately, retail price is something like $40, at the time though I got it for $15.
It's not the greatest, as it uses NiMH batteries, as opposed to the better Li-Ion ones, but what I like about it is that it's inductive, so it'll work with the sleeves on for the times I'm with family with young kids, and it also works with or without the MotionPlus.
I can see the argument for rechargeable AAs. They'll probably last longer, and they're cheaper, especially if you already have a good charger for them.
However, I just find it more convenient to have a dedicated charger. I've got rechargeable AAs that I use in a number of things, but it's a pain if I have to take out the batteries from inside the remotes and charge them, when I really already wanted to be playing. And then if you have the sleeves on, you have to take them off to take out the batteries and put them back in, and I just find having a cheap set of Wii-specific batteries easier.
And since it's just a cheap set, I don't worry about doing a full discharge-charge cycle like you're supposed to do with NiMH batteries, and put them on the charger whenever I'm done. With my good Eneloop AAs, I'd rather not do that.
XBL/Steam: JHoff80
jhoff80 is offline
Old 03-22-2010, 12:21 AM
DavidEC's Avatar
Most all rechargeable batteries on the market today have a "memory" it is best to not allow them to become fully discharges and to recharge at different levels of discharge.... rotate / change the amount of play time between recharge ....and the batteries will last longer.
http://en.wikipedia.org/wiki/Memory_effect
DavidEC is offline
Old 03-22-2010, 02:37 PM
jhoff80's Avatar
Quoted: 389 Post(s)
Liked: 347
To clarify, that's only with NiMH (nickel-metal hydride) batteries as I was implying, and not the better Li-Ion (lithium ion) battieries.
Lithium ion batteries on the other hand work better if frequently topped off.
XBL/Steam: JHoff80
jhoff80 is offline
