Need to Connect a Wii to HDMI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 05-30-2010, 09:26 AM - Thread Starter
RedSwirl's Avatar
My brother bought a house where the living room entertainment center was already set up so that you could only hook up stuff through an HDMI setup in a nearby closet. He's trying to figure out how to rig a Wii up to this thing (it really is probably the best console for him).
What's the best converter he could use to get both his video and audio running through an HDMI cable? Also, he'll need a wireless sensor bar.
RedSwirl is offline
post #2 of 13 Old 05-30-2010, 09:48 AM
Shadowboricua's Avatar
http://hd.engadget.com/2010/05/28/wi...-more-no-less/
Shadowboricua is offline
post #3 of 13 Old 05-30-2010, 09:51 AM - Thread Starter
RedSwirl's Avatar
Saw that, does it really work? If so, I can't seem to find anywhere else to buy it.
RedSwirl is offline
post #4 of 13 Old 05-30-2010, 03:10 PM
darklordjames's Avatar
Liked: 94
It looks like a "good enough" device. At $40 it isn't going to be the greatest thing ever made, but for getting good enough 480p out of a Wii over HDMI, it should get the job done. No one here has tried it out though. I can't imagine that the quality would be too noticeably different from HDMI, plus it will let him hook up the Wii as his system requires.
Also, Neoya sells it directly. Why would you need anywhere to buy it from?
darklordjames is offline
post #5 of 13 Old 07-09-2010, 04:54 PM
PAUL250268's Avatar
Hi
Has anybody tried this set-up yet?
I have the same issue.
Just to be clear, I need to go from Wii into the receiver, Onkyo TX-SR507.
Or, how about a converter box, anyone tried that?
http://www.amazon.com/dp/B003ABST3G/...SIN=B003ABST3G
Paul
PAUL250268 is offline
post #6 of 13 Old 07-09-2010, 10:24 PM
Liked: 94
It's quite probable that the component to HDMI ADC inside of each unit is the same. Again, at $40, both are more than likely "good enough" considering the Wii's 480p output.
So Paul, you have the Wii and the receiver in different rooms with only an HDMI cable run between them? Why? Why not have them in the same room and just hook the Wii up component?
EDIT: Now I see. The receiver doesn't do HDMI upconversion. Is it new enough that you can still return the receiver? I fail to see the logic in buying an HDMI receiver that doesn't have HDMI upconversion, but then having non-HDMI devices that you want to hook up to it.
post #7 of 13 Old 07-10-2010, 06:22 AM
mcmushx15's Avatar
No a direct answer however this is why when you wire your receiver, home etc..., you wire every cable. heck, even Composite and S-Video if you have it. You never know what you want to hook. Of course, all this is not needed if you have a scaleing receiver or something else to convert your signal. Cables are not that expensive these days.
mcmushx15 is offline
post #8 of 13 Old 07-10-2010, 06:30 AM
PAUL250268's Avatar
Hi
Cannot return the receiver, 18 months old. Wii was in game room upstairs but now the wife wants it in the family room. ALL other equipment is HDMI, FiOS, XBox 360, Blu Ray. I do not want to take the TV off the wall and run component cables behind the wall to the receiver about 12 feet.
So, do I have any options? I can't understand why Wii isn't HDMI.
Paul
post #9 of 13 Old 07-11-2010, 01:19 AM
Leo_Ames's Avatar
Quoted: 147 Post(s)
Liked: 257
It doesn't have any HD capabilities so there wouldn't be much gained by including a HDMI port besides increasing Nintendo's cost per unit. Your situation is fairly unusual I would think.
Leo_Ames is offline
post #10 of 13 Old 07-11-2010, 08:10 AM
PAUL250268's Avatar
Doesn't everyone want just one feed into the TV via HDMI?
post #11 of 13 Old 07-11-2010, 09:51 AM
GTarrant's Avatar
I picked upt this unit a few months ago to make all my components HDMI into my scaler. It has scaling capabilities that I do not use. It might be something to consider.
http://www.vdigi.com/index.php?page=...hk=1&Itemid=53
GTarrant is offline
post #12 of 13 Old 07-12-2010, 11:51 AM
AceStallion's Avatar
i hear wii has no HDMI connection and that 480p is the max...i hope i heard wrong...
--Ace
--PSN: AceStallion
----Wavee baby!
AceStallion is offline
post #13 of 13 Old 07-23-2010, 10:51 PM - Thread Starter
RedSwirl's Avatar
That is the truth. The Wii isn't an HD-capable machine.
When Nintendo released this thing in 2006 the HD penetration rate was still pretty low, and their objective was to release a console that was cheap both for consumers and developers who wanted to make games for it. Sales-wise I think that paid off, as a lot of people out there still don't give a crap about HD.
RedSwirl is offline
Reply Nintendo
