Wii and Sharp 55" HDTV - AVS Forum | Home Theater Discussions And Reviews
Old 07-07-2010, 05:44 PM - Thread Starter
nickbaum's Avatar
Hi folks,
I just received a new Sharp 52 inch LED TV (LC52LE700), and my Wii doesn't look right on it. Wii Sports displays interlacing glitches and has noticeable lag. I'm connected by the standard composite cable (so 480i).
The strange thing is that I tried out a Samsung 50 inch plasma last week (PN50C550) and it had none of these issues.
Questions:
* has anyone experienced this?
* what could this be due to? is the Sharp scaler that much worse?
* will getting a component cable and using 480p solve this?
Cheers,
-Nick
nickbaum is offline
Old 07-07-2010, 06:32 PM
ThisOneKidMongo's Avatar
Liked: 77
It might not solve it completely, but going component/480p on the Wii will almost certainly be a vast improvement, both in terms of lag and PQ. Wii Sports was practically unplayable on my old Samsung DLP, but was much much better after hooking up the component cables. Some scalers are just laggier than others.
ThisOneKidMongo is offline
Old 07-08-2010, 07:42 AM
voodoozen's Avatar
Liked: 46
+1 for component cables. May not solve your problem entirely, but it can't hurt. And for <$10 shipped... you're not risking much to find out! Hit the link at the top of the forum here, search for product code 5689, spend $3.90 + shipping and let us know if you get any improvement.
Next: Is your Wii set to 480p in the settings menu? Your Aquos won't have to do as much work when upscaling/not deinterlacing 480p @ 60FPS.
Another: Did you run the Wii+Sammy in the same room and lighting conditions? You might be getting some stray reflections or interference depending on conditions in the room. If it's the same as previous setups, it's the TV. See input above.
last thought: A quick search of avs turned up [spoiler alert]the Sharp 700 series thread... try some setting tweaks.
http://www.avsforum.com/avs-vb/showt...3#post18875573
Originally Posted by Posted by Morning5 View Post
You will get less lag:
1) Using Game, User or Standard A/V Modes.
2) Using Input 7. (HDMI input, won't work with Wii)
3) Reducing the Contrast, Color.
4) Disabling Film Mode.
5) Disabling Noise Reduction
6) Updating to the latest firmware.
Settings:
OPC - Off
Backlight +10
Contrast (White Level) +25
Brightness (Black Level) -3
Color 0
Tint +2
Sharpness +2
C.M.S. Hue 0
C.M.S. Saturation 0
C.M.S. Value 0
Color Temperature (Set the Low preset to the following numbers for 6500K)
Red Gain (Lo) -16
Green Gain (Lo) +3
Blue Gain (Lo) -20
Red Gain (Hi) -15
Green Gain (Hi) +6
Blue Gain (Hi) -21
Fine Motion - On
Gamma +2
Film Mode - Advanced High
Digital Noise Reduction - Auto
voodoozen is offline
Old 07-08-2010, 08:08 AM
c-not-k's Avatar
FWIW I have a 52" 77U and a Wii connected via the optional component cables. So far, no issues. I recommend that solution also.
c-not-k is offline
Old 07-08-2010, 12:18 PM - Thread Starter
nickbaum's Avatar
Great, thanks to all, and particularly voodoozen for the super thorough response!
I've ordered the component cable (it was their daily deal yesterday, fancy that!). Once I get that I'll switch it to 480p and tweak the settings.
So am I correct that the difference could be attributed to a different quality scaler? Conditions were exactly the same when testing both TVs.
-Nick
nickbaum is offline
Old 07-08-2010, 01:24 PM
Liked: 77
Correct me if I'm wrong, but doesn't LCD generally have more of a problem with lag than plasma?
Old 07-08-2010, 01:57 PM
KoRn's Avatar
Quoted: 66 Post(s)
Liked: 37
This day and age. Composite cable should be killed off. The worst cable you could use on a nice tv like that. Get some component cables and run it at 480p. Some tv's though actually look better running it at 480i though with component cables.
KoRn is offline
Old 07-08-2010, 03:19 PM
darklordjames's Avatar
Liked: 94
"Correct me if I'm wrong, but doesn't LCD generally have more of a problem with lag than plasma?"
Given that the scalers inside of each are what cause lag issues, and the scalers are the same regardless of display type, you are wrong. For example, a Samsung plasma versus Samsung LCD of the same range will have the same scalers and the same lag, roughly.
darklordjames is offline
