Connecting my Wii to a ceiling mounted projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-13-2010, 05:41 PM - Thread Starter
myhousekey's Avatar
I'm planning to hook up my Wii to a ceiling mounted projector. The first obstacle I'm seeing is finding a component video cable with the Wii connector that is long enough (I'm guessing I need something in the 25 foot range).
What's the best solution for me to get the 480p video feed from the Wii to my projector?
The projector has the following available inputs:
Component
Composite
HDMI
S-Video
VGA
RS-232
Is it best to run the cable thru a convertor box of some kind near the Wii console?
Thanks in advance for the help.
myhousekey is offline
post #2 of 7 Old 07-13-2010, 06:41 PM
darklordjames's Avatar
Liked: 94
It's pretty easy to extend component with a couple of female to female barrel connectors. Check out monoprice.com.
darklordjames is offline
post #3 of 7 Old 07-14-2010, 08:22 AM
jwebb1970's Avatar
Liked: 38
I got a component coupler from them once - think it ran me under $1 shipped as part of a larger order.
Money does not buy happiness. It can, however, buy you a giant boat that you can pull up alongside happiness. - David Lee Roth
jwebb1970 is offline
post #4 of 7 Old 07-14-2010, 01:12 PM
tank3467's Avatar
I assuming (guessing) you are going to use a receiver to run audio, because projectors don't give off much volume. I personally hook the wii to the receiver then component out to the projector. This way if for some reason you need use component from something else (not sure what that would be but..) you can just hook it up to the receiver.
I second monoprice, they have 25 and 50 ft length cables for cheap.
tank3467 is offline
post #5 of 7 Old 07-14-2010, 10:27 PM
filecat13's Avatar
Quoted: 34 Post(s)
Liked: 101
Yes, I have the typical short Wii video out to component cable, coupled with a female/female connector to a 25' component cable, and it works fine.
What I can afford, when I can afford it...
filecat13 is offline
post #6 of 7 Old 07-15-2010, 12:05 PM - Thread Starter
myhousekey's Avatar
Thanks guys. I appreciate the responses.
And yes, I had planned to run audio via a receiver.
post #7 of 7 Old 07-21-2010, 08:50 AM
djearl81's Avatar
Quoted: 12 Post(s)
I run the Wii through my ceiling projector. Went with monoprice component cables out of the Wii to the receiver's component input. Then a 35' component cable from the back of the receiver to the projector. Works like a champ....treat the wii just like any other a/v component.
Welcome to the world of big screen gaming.
I'm confused too.
djearl81 is offline
Reply Nintendo
