N64 Cable question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-25-2010, 11:58 AM - Thread Starter
champer's Avatar
I have a universal S video cable that has the analog ports for the xbox ,ps2, Nintendo consoles before the wii, and Dreamcast
But i noticed on the Nintendo connector it only has 3 yellow gold pins inside. If you look at the analog connection on the N64 console it has 6 gold pins.
am i using a cheap cable ? Should i google for like a monster gamecube Svideo cable or an official Nintendo one that has more pins on the port to match the console so maybe it will look better ?
cause the consoles port has the 6 gold pins for a reason or what ever they are called
I hooked it up to my tv and i know its not supposed to be HD or anything but the video seems kinda laggy in a way.
but my dreamcast looks ok
Yeah i know i dont have anything else to do with my life except hook up my N64 to my HD TV on thanksgiving. lol
SONY 32XBR6
SAMSUNG 46C6500
BD 40
HD DVD 28
champer is offline
post #2 of 8 Old 11-25-2010, 02:57 PM
thebard's Avatar
Quoted: 88 Post(s)
Liked: 51
http://pinouts.ru/Game/n64video_pinout.shtml
Is it an s-video only cable? They may have omitted the composite out.
Maybe omitted mono audio as well... and ground?
Projectors: Where there's a wall, there's a way.
http://www.avsforum.com/forum/110-di...een-build.html
thebard is offline
post #3 of 8 Old 11-25-2010, 03:24 PM - Thread Starter
champer's Avatar
It has S video and composite. whats the ground connectors for ?
SONY 32XBR6
SAMSUNG 46C6500
BD 40
HD DVD 28
champer is offline
post #4 of 8 Old 11-25-2010, 06:22 PM
darklordjames's Avatar
Liked: 94
At minimum a N64 S-video connection requires 5 pins. Video Y, Video C, Audio Left, Audio Right, common ground. A 6th pin would be required for the addition of composite. Either you aren't counting all the pins because they are hidden from view, or your cable is a piece of crap.
darklordjames is offline
post #5 of 8 Old 11-25-2010, 08:51 PM - Thread Starter
champer's Avatar
only 3 in there as you can see so no i didnt miss count unless the other pins are invisible. now i do get a picture with color and i do get audio but everything on the edges seems laggy.
and whats the commong ground pin for ?
SONY 32XBR6
SAMSUNG 46C6500
BD 40
HD DVD 28
champer is offline
post #6 of 8 Old 01-27-2011, 08:32 PM - Thread Starter
champer's Avatar
I just bought an S video cable for the gamecube off of ebay and it only has 3 gold pins as well. where can I get a decent S video cable to use on my N64. the 1st cable i listed is a universal one with 3 pins as well. this new cable is just for the Nintendo consoles.
SONY 32XBR6
SAMSUNG 46C6500
BD 40
HD DVD 28
champer is offline
post #7 of 8 Old 04-08-2011, 06:23 PM
voidhawk's Avatar
i know this is a bit old, but i have some info.
i have a generic adapter that's ps2/xbox/nintendo (8-bit -> n64) ...and it has 6 pins inside the adapter. I got it at my local gamestop for $10 or $15 I think. It's quite an improvement using S-Video instead of the RCA (especially on the super nintendo). The original nintendo, super, & n64 all look better with this cable.
i have a component cable on my gamecube and wii, which both look better than the original cables.
voidhawk is offline
post #8 of 8 Old 04-13-2011, 12:56 AM
Leo_Ames's Avatar
Quoted: 150 Post(s)
Liked: 262
Originally Posted by voidhawk View Post
It's quite an improvement using S-Video instead of the RCA. The original nintendo, super, & n64 all look better with this cable. .
You couldn't of used a s-video cable (Or even the same composite cable as used on later Nintendo consoles until the Wii) on a original Nintendo.
Neither revision of the console, as built, had s-video support or even the standard multi-out video port used on the SuperNes/N64/GCN.
Leo_Ames is offline
Reply Nintendo
