DPG video server and client like tversity - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-29-2011, 10:10 AM - Thread Starter
maru487's Avatar
So in my quest for streaming movies to the DS I have found a couple of issues:
1. Wifi is too slow
2. DS can't handle the decoding
So unless I am way off, why couldn't a TVersity like server work with the DS to convert videos on the fly?
First problem (wifi):
802.11b is up to 11Mbits/sec but usually runs at 1-5Mbits/s.
An average DPG is 300 - 500MBytes, that would be 8*300 - 500Mbits = 2400 - 4000Mbits
An average movie length is 90-120 minutes = 5400 - 7200 seconds
So using the worst case of 4000Mbits and 5400 seconds you get:
4000Mbs/5400s = 0.74Mb/s
Thats 25% less then the worst case scenario of 802.11b. The DS wifi can can handle that just fine
Second Problem (decoding):
If the unit can decode a dpg, there should be no difference if it's a streaming DPG.
Anyone? This seems to simple for someone to miss, so I must be missing something?
maru487 is offline
Reply Nintendo
