Wii Connections component vs composite - AVS Forum | Home Theater Discussions And Reviews
Old 02-16-2011, 12:10 PM - Thread Starter
bryanpereira's Avatar
I was browsing in a store and came across a third party cable to connect the output on the wii to a component outputs and standard RCA L&R jacks.
has anyone noticed a differnece using the component output rather than the composite given the signal is not HD?
viewing on a 50 inch HD Plasma
thanks!
B
bryanpereira is offline
Old 02-16-2011, 12:31 PM
Leo_Ames's Avatar
Quoted: 147 Post(s)
Liked: 257
Component video isn't useful just because it's capable of carrying an HD signal.
It provides a nice boost in visual quality even at 480i hooked up to a standard definition CRT. That's why the majority of standard definition CRT's produced over the last decade or so of production included a component connection, even including budget ~13" sets over the last few years.
It's split into three signals so there is less signal degradation and the television is able to recieve the most accurate representation of the video being sent to it compared to composite or s-video. I'll spare the technical details for someone more tech savvy to explain to you why it's to your advantage to use, but suffice it to say that it will give the picture quality a nice boost at any non HD resolution. So it's very worthwhile using on the Wii despite it's lack of HD.
It's also the only way to get 480p output from the Wii, which will further increase the picture quality if you have an EDTV or an HDTV. And it also can help your experience on an HDTV since the television doesn't have to deinterlace the signal (Most of the time, there is the occasional quality Wii game that is 480i only) which can be problematic in terms of picture quality and input lag if the scaling chip in your set isn't very capable.
It even gives something like an Atari 2600 a nice boost in visual quality after modifying it to be able to output component video. So it's certainly worthwhile on the Wii and very cheap to do these days (You should be able to locate a decent 3rd party component cable for $10 without any trouble), unlike on the GameCube with it's expensive, online exclusive component cables.
Leo_Ames is offline
Old 02-16-2011, 02:05 PM
Ethenolas's Avatar
+1
You will be able to tell the difference. I can.
Ethenolas is offline
Old 02-16-2011, 02:24 PM
Evan E's Avatar
Quoted: 107 Post(s)
Liked: 103
Remember, component connections pre-date HD by many years. They will give you noticeably better picture quality than composite connections regardless of the display you're using.
Evan E is online now
Old 04-08-2011, 07:25 PM
voidhawk's Avatar
+1 i have component on both my gamecube and wii and it looks noticeably better than the RCA cables.
voidhawk is offline
Old 04-09-2011, 06:38 AM
CHAVAN30's Avatar
yes, you will notice a finer, less "jaggy" appearance.
CHAVAN30 is offline
