Can't get Wii connect to internet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-24-2011, 12:50 PM - Thread Starter
AVS66's Avatar
I have Asus wireless router set up at home. Using wireless with two laptops fine.
Yesterday, I tried connect Wii wireless in order to watch Netflix, I kept getting error code 51330 on the Wii "Unable to connect to internet".
The Wii system is 5ft away from router.
Any helps.
AVS66 is offline
post #2 of 5 Old 03-30-2011, 04:06 AM
DanLW's Avatar
Liked: 37
Is your network secured? Perhaps you need to input the security key into the wireless settings in the Wii.
What type of wireless network is it? B? G? N? I think the Wii works with B and G, not sure about N.
Also, the Wii can be sensitive to interference. Switching the router to a different channel may help.
DanLW is offline
post #3 of 5 Old 03-31-2011, 09:35 AM
voodoozen's Avatar
Liked: 48
Yep- Wii and 802.11N are a no go. You didn't mention the model number, but if your Asus is an N, just swap it to b/g mode and you should be able to see the network from your Wii.
All else fails, I smell a Monoprice order coming on!
-vdz
voodoozen is offline
post #4 of 5 Old 04-09-2011, 12:49 PM
Fargus777's Avatar
+1 for switching the channel on router. Try 1,6 or 11.
Gamertag: Fargus
Playstation ID: Fargus79
Fargus777 is offline
post #5 of 5 Old 02-11-2014, 09:26 PM
trent5000's Avatar
My Wii constantly disconnects from asus rt n66u router.  Tried everything.  Wii and asus rt n66u router are not compatible.  Asus rt n66u broadcasts poor b/g signals. Tried everything.  Wii and asus routers have compatibility problems.
trent5000 is offline
Reply Nintendo
