Onkyo TX-NR808: Wii audio coming only through front speakers, and VERY quiet - AVS Forum | Home Theater Discussions And Reviews
Old 04-16-2011, 11:46 AM - Thread Starter
Baryn's Avatar
Connecting everything over component into the receiver, which goes to the 5.1.
Anyone have this issue before, or could surmise what it might be?
I'd appreciate it very much, thank you in advance.
Baryn is offline
Old 04-16-2011, 04:47 PM - Thread Starter
Baryn's Avatar
ANSWER
I'm used to port layouts where the component video and audio inputs are arranged in one column per source.
However, below Component Input 1, was the RCA input for the front speakers. I needed to plug the stereo outputs into ports way over on the other side of the input array.
Translation: I plugged the audio into the wrong holes, but it's the manufacturer's fault for making the layout so weird.
Baryn is offline
Onkyo Tx Nr808
