Wii Controls Delayed on my HDTV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-21-2011, 01:37 PM - Thread Starter
mcpoyle's Avatar
When I play any Wii game, the controls are delayed a bit.
Here's my equipment.
Wii > component cable > Pioneer Elite VSX 32 > HDMI > Samsung UN55C8000
I've put the TV into 'Game Mode' which reduces the delay slightly, but it is still present.
I decided to try and set it up with the Wii going directly into the TV, and it worked perfectly as long as I was in game mode.
Is there any setting I can change on my receiver to fix the delay? Would using a different connection help? Thanks!
mcpoyle is offline
post #2 of 2 Old 06-21-2011, 03:12 PM - Thread Starter
mcpoyle's Avatar
I decided to go out and pick up a component cable because I want 480p over 480i anyways, and that has fixed the problem. It can now run through my receiver without any problems as long as my TV is in Game Mode. Looks like the receiver doesn't like 480i.
mcpoyle is offline
Reply Nintendo
