Wii and Denon AVR 390 - audio ok, video black - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-22-2011, 09:30 AM - Thread Starter
endelwar's Avatar
Hi!
I have a denon avr-390 connected via HDMI cable to an Optoma projector (I have no TV at home) and tried to connect a Wii console (PAL european version, set to 576i) to it using its standard composite cable (yellow/red/white): audio is working ok, but there is no video output.
If I connect the composite video cable (yellow) directly to the Optoma it works.
If I connect an XBox 360 to the same RCA connectors it works so the RCA to HDMI conversion is working.
What can I try to make it works?
endelwar is offline
post #2 of 3 Old 09-22-2011, 04:56 PM
pjb16's Avatar
Are you sure your Denon accepts 576i signals?
PSN - Mr_Frisch
XBL - Mr Frisch
Steam - Sneaky Pete
pjb16 is offline
post #3 of 3 Old 09-23-2011, 12:42 AM - Thread Starter
endelwar's Avatar
Yes, these are the supported video mode: 480i/480p/576i/576p/720p/1080i/1080p
endelwar is offline
Reply Nintendo
