Best CRT for Wii gaming? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-19-2012, 12:21 PM - Thread Starter
GeneraLight's Avatar
Quoted: 42 Post(s)
Hello, I am searching for the best CRT available for playing the Wii.
It must have:
1) Zero input lag
2) Native 480p support
3) Flat screen
4) Excellent motion handling and picture quality
Optional:
Native Widescreen 16x9
I've heard the Sony FD Trinitron KD-34XBR960 is the highest standard for Wii gaming, but I always find them too far away from Ohio and thus have ridiculous shipping costs (I believe UPS gave me a quote of $750 from California to Ohio).
I bought official Nintendo component cables for my Wii, allowing the Wii's maximum output resolution of 480p. So, I need a CRT with component cable inputs. I also need a CRT with zero input lag. This is a must because I play games competitively online and speedrun, so zero input lag is mandatory. Something I'd like but is not mandatory is native 16x9 widescreen and a flat screen.
Thank you.
GeneraLight is offline
post #2 of 9 Old 05-21-2012, 01:07 AM
G-Bull's Avatar
You wont find many (any?) 480p native CRTs anymore. That's EDTV resolution, and once HDTVs hit the marketplace it was largely abandoned. That Sony 960 is a 1080i HDTV and will upconvert a 480p signal to 1080i. I think 480p CRTs existed once, 20 years ago.
G-Bull is offline
post #3 of 9 Old 05-23-2012, 03:00 PM
sage11x's Avatar
Quoted: 1094 Post(s)
Liked: 1052
The difference between 480i and 480p is negligible on a CRT as a CRT can display interlaced sources properly without conversion. That's the beauty of CRT tubes and rear projectors: they're not fixed pixel displays and can display a source in it's native format without needing to scale, de-interlace or otherwise resize the image.
CRT tubes are needlessly bulky for being as small as they are and if you go flat screen and/or widescreen the weight to screen size ratio is going to be that much worse! I still have an old 27" toshiba cinema series (standard def) tube that I keep around for classic games and Wii looks great on it but not to the point that I wouldn't just want to play it on one of my HDTVs. Standard def tubes are much cheaper (and lighter) and easier to find as just about everyone had one. I really don't think you're going to notice much improvement with an HD CRT tube. Of course, you could always go CRT rear projection! All the benefit of a CRT tube with a more modern screen size.
Personally, I'd rather just dedicate an inexpensive 42" 720p to the endeavor and call it quits. Panasonic plasmas have ~16ms of lag which is practically non-existent. You may even be able to find a used EDTV plasma (480p) for a decent price but you're still fixed pixel so there's really no reason not to stick with a 720p as the PQ will undoubtably be better on the newer display and you can use it for things other than Wii.
What to do if you find yourself stuck with no hope of rescue:
Consider yourself lucky that life has been good to you so far. Alternatively, if life hasn't been good to you so far, which given your present circumstances seems to be more likely, consider yourself lucky that it won't be troubling you much longer...
-- Excerpt from the Hitchhiker's Guide to the Galaxy.
sage11x is offline
post #4 of 9 Old 05-23-2012, 03:02 PM
sage11x's Avatar
Liked: 1052
The Sony will display what it's fed in it's native format, so:
480i in, 480i out
480p in, 480p out
1080i in, 1080i out
sage11x is offline
post #5 of 9 Old 07-29-2012, 01:05 AM
kenshin1's Avatar
kenshin1 is offline
post #6 of 9 Old 07-29-2012, 01:07 AM
kenshin1's Avatar
I got mine off Craigslist, 40 min drive to get it
kenshin1 is offline
post #7 of 9 Old 08-03-2012, 08:33 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1704
The XBR960 is arguably the finest CRT even made, but I'm not shocked at all by those delivery quotes. This thing weighs a ton. You need 2-3 people to move it.
Steam/PSN/Xbox Live: Darius510
bd2003 is offline
post #8 of 9 Old 08-03-2012, 08:47 AM
wlcohen's Avatar
that's some serious Wii gamer
wlcohen is offline
post #9 of 9 Old 01-10-2013, 04:22 PM
Amber Ale's Avatar
I had a huge, Sony 32" Trinitron that had hd inputs. The thing took 4 people to move but it was amazing for Wii and Xbox gaming. I found it for $100 at a church garage sale, had to leave it in the last move because it was just too heavy. If I remember correct I think they also made a 40" version. The best gaming tv I've ever owned.
Amber Ale is offline
Reply Nintendo
