¿Wii supports 576P? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-30-2012, 07:21 PM - Thread Starter
calter's Avatar
Let me know if the Wii PAL 576P support real or only support 480P.
I hope answers, thanks.
calter is offline
post #2 of 4 Old 06-30-2012, 09:44 PM
darklordjames's Avatar
Liked: 94
You are in a very US centered forum. We aren't likely to know. avforums.com is probably a better place to ask, as they are UK based.
darklordjames is offline
post #3 of 4 Old 07-12-2012, 02:21 PM
WizarDru's Avatar
It is my understanding that with a component output, the PAL Wii can output at 576p....but that unless the game officially supports it (and virtually none do), all you'll get is a 480p image clumsily upscaled. Japan is an NTSC region, so most games are designed to that spec.
WizarDru is offline
post #4 of 4 Old 07-26-2012, 10:17 PM
Lolicon's Avatar
I'm from the PAL region, so I can help. :-)
I've lots of Wii games, both discs and WiiWare/Virtual Console, and never once have I seen a game that runs in 576p. It's 576i, 480i or 480p.
Normal disc games usually runs in 480p.
Nintendo GameCube discs runs in 480i (if you select 60Hz mode).
VC games runs in 576i, unless they're Hanabi Festival games which usually runs in 480i or sometimes even 480p.
But 576p? Never.
Lolicon is offline
Reply Nintendo
