Wii U sensor bar behind acoustically transparent screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-07-2012, 01:55 PM - Thread Starter
rhowell's Avatar
Can a sensor bar be mounted behind the screen and still have the system pick it up. I am running a PAE 7000 with a 110" screen. I dont want it located at the bottom or top but "behind" the screen.
Regards
rhowell is offline
post #2 of 5 Old 11-07-2012, 02:03 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
The bar is actually an IR light source. So imagine shining a weak LED flashlight through the screen which will probably block it entirely. IR follows the same rules a visible light except we can't see it with the naked eye. Any opaque material will block it.
mdavej is offline
post #3 of 5 Old 11-07-2012, 03:30 PM - Thread Starter
rhowell's Avatar
Thanks. Guess that is the challange with a sensor bar and a large screen.
rhowell is offline
post #4 of 5 Old 11-14-2012, 07:25 AM
bdoyledimou's Avatar
I mounted my sensor bar below the screen. No issues.
PSN: Wrassle
360: Burnt of Wrassl
bdoyledimou is offline
post #5 of 5 Old 08-14-2015, 05:39 AM
Liked: 0
it's easiest to place a sensor bar on a table in front of you somewhere between the screen and where you are.
If you feel like experimenting you could point some IR or red lasers at the screen. The remote has a camera in the tip that looks for four IR dots, which normally come from normal LEDs, but might as well be laser dots.
The acoustically transparent screen doesn't matter. The remote works based on IR light, not ultrasound.
cheatercheater is offline
Reply Nintendo
