Would a wired connection work??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-27-2012, 05:23 PM - Thread Starter
PDX-mom's Avatar
I had my Wii wirelessly connected for over a year without any problems. Then a few days ago it stopped connecting (no changes to anything else). I just spent almost an hour chatting with the guys over at Nintendo to no avail. Might connecting it with a wired connection help?
I know, I should have asked them, but didn't think of it and they never suggested it.
Thanks for your help!
PDX-mom is offline
post #2 of 4 Old 12-27-2012, 08:13 PM
Kurtiebird's Avatar
I've never tried it, but you can buy one of these to get a wired connection on the Wii. It would be worth a shot, and not too expensive.
Kurtiebird is offline
post #3 of 4 Old 12-29-2012, 09:22 AM - Thread Starter
PDX-mom's Avatar
It worked just fine.
It was odd because the wi-fi worked just fine for well over a year before stopping. And the Wii could still see the signal, just couldn't connect to it. Either way, the LAN adapter worked and was very easy to set-up; just wish I had a longer cord available...
PDX-mom is offline
post #4 of 4 Old 12-29-2012, 02:46 PM
darklordjames's Avatar
Liked: 94
http://www.amazon.com/Ethernet-Cable-CAT5e-Connectors-Networks/dp/B000E8DMU8
The key word you're looking for is "CAT5e". CAT6 is overkill with a price bump, and anything labeled as just "ethernet" could be anything.
darklordjames is offline
Reply Nintendo
