Help with video feed from original wii to Onkyo AVX 290 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-29-2012, 07:03 PM - Thread Starter
brivance's Avatar
I am a relative novice when it comes to setting up home theater systems, so I am hoping there is an easy fix to my problem that I have not thought of yet.
I have set up my system and have my wii hooked up to the receiver. When I change my input to "game," I have game sound from the wii, but no picture. I am using the wii composite cables. Any suggestions would be welcome.
brivance is offline
post #2 of 6 Old 12-29-2012, 08:25 PM
MandM's Avatar
Quoted: 82 Post(s)
Liked: 40
What receiver do you own and how is it connected? If your receiver doesn't upconvert video signals you need to run a composite video cable from your receiver to your tv.
MandM is offline
post #3 of 6 Old 12-30-2012, 09:10 AM - Thread Starter
brivance's Avatar
I have an Onkyo AVX 290
brivance is offline
post #4 of 6 Old 12-30-2012, 10:04 PM
MandM's Avatar
Quoted: 82 Post(s)
Liked: 40
Are you running both an HDMI cable and composite (RCA) from the Onkyo to your TV?
MandM is offline
post #5 of 6 Old 12-31-2012, 04:24 AM - Thread Starter
brivance's Avatar
I just have a hdmi cable connecting the receiver to the tv.
brivance is offline
post #6 of 6 Old 12-31-2012, 01:09 PM
darklordjames's Avatar
Liked: 94
That is the problem. You also need to run the same type of video that the Wii is using from the receiver to the TV. Your receiver does not convert incoming composite (yellow cable) or component (green, red, blue) video to an HDMI signal.
darklordjames is offline
Reply Nintendo
