Wii In Stock at Sears.com - 12pm @ 01/30 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-30-2007, 10:02 AM - Thread Starter
oktoberrust11's Avatar
Quoted: 69 Post(s)
Liked: 38
FYI, in stock online:
http://www.sears.com/sr/javasr/produ...TOYS&ihtoken=1
Good luck.
Matt
Xbox Live: oktober rust | Mii: 5207 2388 9861 4135 | Steam ID: detroit820 | Origin ID: oktoberrust11
oktoberrust11 is offline
post #2 of 6 Old 01-30-2007, 10:51 AM
scottro's Avatar
Thanks, I missed it...I was trying to check out for like 40 minutes.
scottro is offline
post #3 of 6 Old 01-30-2007, 10:52 AM
aegisx's Avatar
Something is wrong with that link. It seems that it continues your session (can't do much), but otherwise that product doesn't seem to exist anymore.
aegisx is offline
post #4 of 6 Old 01-30-2007, 12:09 PM
chiguy's Avatar
Now it seems to be back as I get "in stock" and can add to cart, not that I'm looking for one anymore. I've found that all the online retailers seem to come in and out of stock for a while once they have them and you should keep checking over the next hour after they say they're out. Probably from people who put them in their cart, but don't check out then.
chiguy is offline
post #5 of 6 Old 02-14-2007, 07:57 AM - Thread Starter
Quoted: 69 Post(s)
Liked: 38
Updated - 9:57am EST 02/14/07, back in stock.
post #6 of 6 Old 02-14-2007, 09:29 AM
T2k
T2k's Avatar
Thanks, I just sent this link to my colleague - BTW it's still in stock @11:30AM...
UPDATE: ehh, it shows up as in-stock but when you try to check out it's out:
Alert
We're sorry. The item(s) and/or quantity you had in your cart are no longer available.
"See Options below.
Shopping Cart
Continue shopping:
Item Qty. Price Arrival method
This item out of stock. See Similar Items. This item will automatically be removed from your cart.
Wii Console Nintendo Wii Console
Sears Item #05892000000
T2k is offline
Reply Nintendo
