Wii Compatible Routers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 30 Old 02-06-2007, 06:49 PM - Thread Starter
mcarper's Avatar
I am looking for a good router for my little bro to use with the satellite internet my folks just ordered. I figured I would start the thread with the router I use and settings that I put it on to work with the Wii. I am especially interested to see the success with Linksys routers as that is the brand the internet company said works best with their service. Thanks for the input. Here is mine:
Router: Microsoft MN-700
Channel: 11
Mode: b/g
mcarper is offline
post #2 of 30 Old 02-06-2007, 10:20 PM
temeone's Avatar
Quoted: 17 Post(s)
I use a belkin wireless g router and it works fine with my wii. I just had to input the SSID into the Wii menu and it connected right away with all the other settings as default.
temeone is offline
post #3 of 30 Old 02-07-2007, 07:14 AM
Caswell's Avatar
I use a Netgear WGR614 802.11g router. Works great with the Wii despite a few challenges; SSID broadcast is turned off, MAC filtering is on, 128-bit WEP enabled (I know, I should be using WPA), and the signal in my living room is relatively weak.
I've heard reports of the Wii not liking some routers operating in mixed b/g mode. No problems with that here.
They're dirt cheap at any big box store, but I'd consider them a throwaway router based simply on the fact that the antenna isn't replaceable.
Caswell is offline
post #4 of 30 Old 02-07-2007, 07:51 AM
Todd Scott's Avatar
Linksys WRT54G works great too. Using WPA. The router is about 15' away from the Wii, on the same level.
Todd Scott is offline
post #5 of 30 Old 02-07-2007, 11:53 AM
eeebee's Avatar
I have the D-Link DIR-655 Xtreme N gigabit wireless router, running on mixed mode. Works great with the Wii... had no trouble at all configuring the Wii to get it to connect to the router. Also had no problem at all connecting with my PS3. Using WPA,
eeebee is offline
post #6 of 30 Old 02-07-2007, 12:00 PM
spoooon's Avatar
Like temeone, I'm using a Belkin Wireless G, I think in mixed mode, channel 11, WPA. I just entered the SSID and password and was good to go.
spoooon is offline
post #7 of 30 Old 02-07-2007, 12:41 PM
squidboy's Avatar
D-Link DGL-4300. One of the best routers on the market, and works great with the Wii.
squidboy is offline
post #8 of 30 Old 02-07-2007, 01:20 PM
QuadESL63's Avatar
I have the same 802.11g router from Linksys. Works fine with the Wii (and PS3 60GB, iMac, PSP, DS, etc.)
QuadESL63 is offline
post #9 of 30 Old 02-07-2007, 02:28 PM
aC39's Avatar
++ WRT54G in mixed mode works great
aC39 is offline
post #10 of 30 Old 02-07-2007, 07:29 PM
Kil4Thril's Avatar
D Link 624+
will work for sushi
Kil4Thril is offline
post #11 of 30 Old 02-07-2007, 10:06 PM
Revolution2006's Avatar
I hope it works on your satellite internet because I tried using my DS at my friend's house that had WiFi with a satellite internet and it was way too slow and kept having disconnection errors. Not to freak you out or anything......I hope it works!
Revolution2006 is offline
post #12 of 30 Old 02-08-2007, 05:07 AM
wokisan's Avatar
Linksys WRT54GS in mixed mode works great. The Wii would not connect to the network in 'g-only' mode.
Wokisan
AVS / AGE
wokisan is offline
post #13 of 30 Old 02-08-2007, 05:43 AM
mcmushx15's Avatar
yup..must be in mixed
mcmushx15 is offline
post #14 of 30 Old 02-08-2007, 05:59 AM - Thread Starter
mcarper's Avatar
I think it is due to the lag time that comes with satelitte internet. All he wants it for is to download games and such, not for online gameplay. We already know this is a no go.
mcarper is offline
post #15 of 30 Old 02-08-2007, 11:08 AM
blusky75's Avatar
I'm using a Linksys WRT300N Wireless Draft N router (streaming videos to my 360's Media Center Extender interface is a bandwidth hog - couldn't wait for the N draft to finalize any longer). Got 802.11b and g backwards compat turned on. Router is configured with WPA2 encryption. The wii talks to the router without any problems
blusky75 is offline
post #16 of 30 Old 02-08-2007, 07:41 PM
nevets72's Avatar
I've got a Wildblue sat connection along with a Wii. The weather channel, news channel, and Internet channel work fine, but the shop channel only connects about 1 in 3 tries. I think the shop channel may use a variation of the Https protocol and that is what causes the problem, Wildblue messed with there mojo in November, and since then Https sites tend to timeout more then Http sites.
As far as a router, I use a Belkin pre-N one, but I don't think they make it any more.
Hope that helps,
John
nevets72 is offline
post #17 of 30 Old 02-08-2007, 08:42 PM
epsilon72's Avatar
I second that.
epsilon72 is offline
post #18 of 30 Old 02-14-2007, 10:15 AM
jmystikcfl's Avatar
I use a Linksys WRTSL54GS in mixed mode. WPA-TKIP w/SSID broadcast turned on and a really long network key. Aside from having to type in that really long network key, it worked like a charm. Found the network without me having to type in the SSID or anything! I'll be changing it soon to WEP so I can use my DS WiFi too.
jmystikcfl is offline
post #19 of 30 Old 02-16-2007, 01:18 AM - Thread Starter
mcarper's Avatar
Hope that helps,
John
Thanks for the input. I hope we can get the shop channel working for him with wildblue. I will be setting it up for him at the end of March when I go visit.
mcarper is offline
post #20 of 30 Old 02-16-2007, 07:34 PM
nevets72's Avatar
Your welcome,
I will tell you that it has gotten better, I did switch the router to channel 11 (as apposed to 1) and now I can get on the shop channel about 1 in 2, or maybe even 2 out of 3 tries. When you try and connect, wait 5-8 minutes, and if it doesn't go just shut it off (at the Wii, the remote won't work) wait 30 sec. and try again.
As you well know, the fun of the Wii is not in downloading games, but playing them after you have. Hope your brother enjoys.
John
nevets72 is offline
post #21 of 30 Old 02-16-2007, 08:28 PM
Mini123's Avatar
BEFW11S4 doesn't really work for me. It connects during the test, but the update always fails with the 32002 error.
"Although I am already in my pyjamas."
Mini123 is offline
post #22 of 30 Old 06-26-2008, 09:17 PM
caible's Avatar
Not sure where this post needs to be, but I noticed there was a closed forum about hacking the wii sensor bar. There is now a wireless sensor bar available that runs on 4 AA's. It connects the same way the remotes do to the wii. I set mine near my center channel and it works perfectly with my projector. Just wanted to let everyone know.
caible is offline
post #23 of 30 Old 06-27-2008, 08:18 AM
bearybear's Avatar
i went to best buy, spent $45 and got the DYNEX. its wi-fi compatible so picked it up. i did it also cause my son loves mario kart.
bearybear is offline
post #24 of 30 Old 06-28-2008, 07:39 AM
GregLee's Avatar
Quoted: 803 Post(s)
Liked: 259
My phone company supplies a wireless router-modem, a Westell 327W, with my DSL subscription (3000kbps down). I have it set up to broadcast its SSID, use 64-bit WEP encoding, and to use MAC address filtering. The Wii detected the SSID, and as soon as I supplied the WEP key to the Wii and added its MAC address to the table in the router, it worked fine. No problem with the Internet or Shopping channels.
Greg Lee
GregLee is online now
post #25 of 30 Old 06-28-2008, 09:06 AM
dp70's Avatar
I have a D-Link DIR-655 pre-N router, set to WPA2 and non-broadcasting SSID, and it's working fine with the Wii (at G rates, of course).
By the way, that "wireless" Wii sensor bar is only wireless in that it runs on batteries. It doesn't transmit anything. "Sensor bar" is kind of a misnomer, since all a Wii 'sensor' bar provides is two points of infrared light for little cameras in the Wii-motes to see. The cost of parts on the wireless sensor bar is under $3, so it sold at a huge profit to both Nyko and the retailers. With that said, it IS a pretty handy product.
dp70 is offline
post #26 of 30 Old 06-30-2008, 04:42 PM
Wagon Man's Avatar
I have Linksys WRT54GL, but unlike other who use WRT54GS, I use G-Only mode, and I can connects to the web without any issue
Wagon Man is offline
post #27 of 30 Old 02-25-2011, 08:49 AM
panda349's Avatar
i have a dlink dir 655 router and i am having problems getting internet connection to my wii. i went to dlink forums for help and i did everything everyone told me to do but still cant get connected to the internet through the wii. i changed settings on the router to mixed, wpa2 only and aes. i dont have a wep security key which the wii keeps asking for. is there something else i should change on router settings. any help would be greatly appreciated. Thanks.
panda349 is offline
post #28 of 30 Old 03-01-2011, 08:43 PM
Dan Bernet's Avatar
ps3 controller
ps3 dualshock 3 controller
ps3 wireless controller
Dan Bernet is offline
post #29 of 30 Old 03-02-2011, 08:39 AM
jwebb1970's Avatar
Liked: 38
http://www.netgear.com/home/products...y/WNR2000.aspx
Netgear WNR2000 has worked well with everything in the house, incl 3 WiFi products (Wii, iPod Touch & Kindle) utilizing the wireless @ the same time
Money does not buy happiness. It can, however, buy you a giant boat that you can pull up alongside happiness. - David Lee Roth
jwebb1970 is offline
post #30 of 30 Old 03-17-2011, 07:23 PM
Photokid1970's Avatar
Quoted: 20 Post(s)
ps3 controller
G-only? I can't get my Wii to see my Linksys E-3000 unless I put the 2.4 channel in mixed mode. The Nintendo channel shows were stuttering really bad when I did that. So I connected a D-Link 655 and set that at B-only. The E3000 has a 5 Ghz N-only channel and a 2.4 Ghz G-only channel.
Now my 5 Ghz N-only channel is great, but my 2.4 Ghz channel suffers really bad with slow speeds. Charter came and said I shouldn't connect two wireless routers together and I should stick with just the Linksys. I wish the DS/Wii/PSP would accept G speeds so I could stop this madness!
Photokid1970 is offline
Reply Nintendo
