Eliminating the audio signal from HDMI wire?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-07-2011, 06:42 AM - Thread Starter
PimpUigi's Avatar
I have a PC connected to my TV via HDMI for video, and via RCA for audio.
Recently, I upgraded my video card (GTX560 Ti), and apparently the new video card supports audio over HDMI, so my TV (XBR960) won't accept sound over the RCA connection anymore.
I can have either audio on the TV, or audio on PC, but not both.
If I could eliminate the audio signal from the HDMI wire, this would be solved.
I have connected with a DVI to HDMI adapter, and it still sends the audio over anyway, which I didn't know was possible.
I really want to have audio on both the PC and TV, for games and everything...
PimpUigi is offline
post #2 of 5 Old 03-07-2011, 07:07 AM
MSmith83's Avatar
Quoted: 232 Post(s)
Liked: 191
Make sure that the other sound device with the RCA output is set as the default device in the sound section of Windows' control panel.
To completely cutoff audio from the graphics card's HDMI output, you can disable the NVIDIA sound device in the same control panel by right-clicking the device and selecting "Disable."
You could also do the following for other circumstances:
Open up the "NVIDIA Control Panel"
Click on "Change resolution" under the "Display" tab
Select the relevant display
Change the "Connector" type from "HDMI - HDTV (Audio Enabled)" to "HDMI - HDTV (Audio Disabled)"
MSmith83 is offline
post #3 of 5 Old 03-11-2011, 03:46 PM - Thread Starter
PimpUigi's Avatar
Hm, seems I can't change that option. It doesn't even look like an option.
Perhaps it's only available in Vista/7 ???????
PimpUigi is offline
post #4 of 5 Old 03-11-2011, 08:24 PM
MSmith83's Avatar
Quoted: 232 Post(s)
Liked: 191
Yeah, my instructions were for the Vista/7 environment.
It has been a long while since I've used XP at home, but I believe it doesn't play nearly as nicely with multiple sound devices.
One thing you could try is to uninstall the Nvidia sound driver, which is a separate component in the overall driver set. I believe it is called "NVIDIA HD Audio Driver."
MSmith83 is offline
post #5 of 5 Old 03-11-2011, 08:34 PM - Thread Starter
PimpUigi's Avatar
Unfortunately that won't fix it either.
I guess I'll have to wait for a driver update.
PimpUigi is offline
Reply HTPC Gaming
