Good HTPC case for a GTX 460 - AVS Forum | Home Theater Discussions And Reviews
Old 06-28-2011, 09:38 PM - Thread Starter
Mako0312's Avatar
I plan on putting a GTX 460 768mb in my HTPC. Just because I have it laying around.
The case I really like is the SilverStone GD01B-R. Also my 2600K is going into it. So suggest a case + motherboard that would work well with the GTX 460 while keeping the same part of my equipment type look.
Mako0312 is offline
Old 06-30-2011, 05:17 PM
WJonathan's Avatar
Is the card's cooler an internal vent or rear case vent?
WJonathan is offline
Old 06-30-2011, 06:43 PM - Thread Starter
Mako0312's Avatar
Internal.
Its a Galaxy one.
Mako0312 is offline
Old 07-01-2011, 05:26 PM
WJonathan's Avatar
In that case you need at least one 120 MM fan near the top of the case to pull the combined GPU+CPU produced heat away. More airflow near the top rear and top, um top, will help you out.
