Need advice on converting gaming PC to HTPC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-30-2011, 04:02 AM - Thread Starter
DrTesla's Avatar
Hello all.
I'm looking for advice on making my gaming PC more of a home theater. I have a pretty decent computer (upgraded last year or so) so I need advice on the display and audio.
I've posted what I'm looking for in a display on the "help me choose an LCD" thread. I'd post a link but I haven't posted enough.
Aside from that, I need advice for the sound system, price range is up to $500, and I've been looking at a 5.1 sound bar (Sony I think).
How important is the refresh rate on the TV, what about the video card?
I'm running an amd quad-core 3.2ghz, rad5870, and 8gb 1600 ram.
DrTesla is offline
post #2 of 6 Old 08-30-2011, 05:38 AM
mudfrog's Avatar
Quoted: 20 Post(s)
That setup will make a nice gaming HTPC. As for the sound, will you be running a receiver?
There really isn't a "conversion" from a gaming PC to a HTPC, the main difference is if you use media software like XBMC, etc..
Equipment - 60" Vizio M60-C3 - Denon AVR-2300W - Pioneer BDP-150 - HTPC, Xbox One - Sennheiser RS170 Headphones - APC C25B Power Filter
Speakers - SVS Prime Center, Bookshelves, Satellites, Dual BIC F12 12" Subs
HTPC - Intel Core i3-3220, 8GB DDR3 1600, 750ti 2GB, 7TB of HDD's, LG Bluray
mudfrog is offline
post #3 of 6 Old 08-31-2011, 12:38 AM - Thread Starter
DrTesla's Avatar
To be honest I'm not well versed in the audio department. So I'll probably end up running whatever is easiest to set up and get working.
DrTesla is offline
post #4 of 6 Old 08-31-2011, 09:34 AM
mudfrog's Avatar
Quoted: 20 Post(s)
I went with the Onkyo Jamo package on Tiger Direct. It's cheap and should sound really nice for an entry level system. Just had to add a sub but for the entire setup (including BIC F12 sub) I only have about $640 in it. I know it's out of your budget but it's worth a look.
mudfrog is offline
post #5 of 6 Old 09-10-2011, 10:47 AM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
I would also consider buying the receiver and the speaker package separately as an option. Check accessories4less for great deals on HT receivers. They have factory reconditioned and warrantied Onkyos that you can get into the base models for good prices. I've used them a couple of times to help out relatives with setting up a similar priced system. Good seller.
Once you have priced out your receiver and know how much you have left, I'd recommend researching in the speakers forum on AVS and/or asking there. A good HT speaker setup will be good for gaming, too, so they can help. You can get some good recommendations that way, and they will know all the current specials.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #6 of 6 Old 09-10-2011, 12:41 PM
DaveFi's Avatar
Quoted: 71 Post(s)
Liked: 33
If you're going to get a receiver with HDMI support (which I recommend) any of the newer ATI cards will do as they all support bitstreaming audio or you can go for a Nvidia 560 which also supports it. I have 3 ATI 6950s in Tri-Crossfire and they work quite well.
You really don't have to invest a lot of money anymore to have a decent gaming/HTPC setup.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is offline
Reply HTPC Gaming
