Whaaaaa? RAM not being used. - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 34 Old 12-02-2012, 01:43 PM - Thread Starter
tomfoolery_79's Avatar
Update to my Update (happier update) ----
I pulled out all the RAM except 1 stick and got everything to boot properly. I concluded, I have a bad stick just need to find out which one.
STEAM: Augcliffe
PSN: Augcliffe
tomfoolery_79 is offline
post #32 of 34 Old 12-02-2012, 01:57 PM
darklordjames's Avatar
Liked: 94
Pull out all the ram and put a single stick back in. Does it boot? Find the jumper on the motherboard that clears the CMOS. Does it boot? Plug the monitor in to the onboard GPU. What happens?
EDIT: I was reading the thread when you made your last update. smile.gif
darklordjames is offline
post #33 of 34 Old 12-04-2012, 06:02 AM
guy80's Avatar
At that [all the above] point I'd also look at BIOS versions & what they fixed & flash back/fwd -- at least before you determined it was a bad stick.
I'll be running memtest & spinrite on my new laptop before trusting it. I have a hard time trusting HDD after my Macbook had a lemon.
guy80 is offline
post #34 of 34 Old 12-09-2012, 05:30 PM
HeadRusch's Avatar
Quoted: 119 Post(s)
Liked: 91
Did you pull all of the ram out except for 1 single stick and see if it will post?
Xbox Live / PS3 / Steam: HeadRusch1
Keeping the world safe from the evil antics of Bernie Tanaka and Mel Fujitsu since 1986
HeadRusch is offline
Reply HTPC Gaming
