Connecting PC to Panasonic TH-37PW5 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-06-2012, 07:09 AM - Thread Starter
phorts's Avatar
This is not a high-tech gaming rig, and hence not a high-tech question, but i didnt know where else to post this. Thanks for any insight you can provide.
I got a 36" Panasonic TH-37PW5 Plasma from a yard sale for $20 and want to hook up my PC to it. The TV only has Component and VGA inputs. When i hook up my PC it only displays up to 1072x600. The video card is an integrated Intel 82865G.
Obviously this res is not very satisfactory.
What do i need to do to get a higher res with this TV? Is that the max it can display? Is the video card limiting and do i need a new one?
Or, is it a Windows setting? (Slider is set to max and refresh rate is 61hz (only option).
Or, is it a TV Setting?
Thanks again for any advice and insight you can provide!
PS - looking mostly to use this as a PC monitor, watching some video, no gaming really. Just want crisp(er) text and web pages to fit on the screen! lol.
phorts is offline
post #2 of 6 Old 02-06-2012, 07:21 AM
WiseGuy2k7's Avatar
I put the model no. in a google search and from my findings its a limitation of the panel. Max resolution is suppose to be 852x480, which is a very weird resolution. Most likely this is the reason it was only $20, as it cannot not display true hd. Here is a link for you to check out on the specs.http://www.dooyoo.co.uk/plasma-tv/pa...37pw5/details/
PSN:The_Wise_Guy
XBL:DirtySanWiseGuy
Steam:The_Wise_Guy
BF4 PC:The_Wise_Guy
WiseGuy2k7 is offline
post #3 of 6 Old 02-06-2012, 07:30 AM - Thread Starter
phorts's Avatar
Yeah that's what i was thinking, but found it strange the PC allowed it to go to 1072x600.
I have a Pioneer PDP-5080HD which is a 720p Panel (max res 1365x768) and seem to remember getting higher res when connecting to a PC. My memory could serve me wrong, however.
Thanks for the quick reply WiseGuy, Anyone with a difinitive answer on this one?
phorts is offline
post #4 of 6 Old 02-06-2012, 08:08 AM
mhufnagel's Avatar
Quoted: 22 Post(s)
Liked: 92
I remember seeing Panasonic and Phillips EDTV Plasma's around the time I bought my first HDTV (Jan 2006). They were 42" models and selling for around $1000. With a 852x480 (480p) resolution, this is a EDTV. I never saw a 36" version, this is probably an older model. I bet it would work really nice with last-gen gaming systems, or a Wii, that can only go up to 480p. I sure wouldn't use it with a pc though.
mhufnagel is offline
post #5 of 6 Old 02-06-2012, 08:17 AM - Thread Starter
phorts's Avatar
Ok fair enough. Wii screen it is! (guy told me he paid $8000 for it... i figured that was laughable). But, a nice $20 purchase all the while.
Thanks guys!
phorts is offline
post #6 of 6 Old 12-01-2014, 10:49 PM
Liked: 0
Originally Posted by phorts View Post
This is not a high-tech gaming rig, and hence not a high-tech question, but i didnt know where else to post this. Thanks for any insight you can provide.<br><br><br>
I got a 36" Panasonic TH-37PW5 Plasma from a yard sale for $20 and want to hook up my PC to it. The TV only has Component and VGA inputs. When i hook up my PC it only displays up to 1072x600. The video card is an integrated Intel 82865G.<br><br>
Obviously this res is not very satisfactory.<br><br>
What do i need to do to get a higher res with this TV? Is that the max it can display? Is the video card limiting and do i need a new one?<br><br>
Or, is it a Windows setting? (Slider is set to max and refresh rate is 61hz (only option).<br><br>
Or, is it a TV Setting?<br><br>
Thanks again for any advice and insight you can provide!<br><br><br>
I have this plasma tv it is actually an 37" not 36
Nitameyer is offline
Reply HTPC Gaming
