HDMI to TV to Optical Out to 5.1 Speakers...will i get 5.1 audio? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 02-06-2012, 01:06 PM - Thread Starter
jorlanm's Avatar
Ok im getting a Toshiba 42Tl515U and a Logitech Z906 5.1 speaker system...
The specs of the Toshiba 42Tl515U says it outputs Dolby Digital on Optical Out.
The specs of the Logitech Z906 5.1 speaker system says it decodes Dolby Digital.
My plan was hooking up my PS3 and XBOX360 set on Bitstream hooked up to the TV via HDMI...then hook an Optical Cable from the TV to the 5.1 Reciever...
Will I get Dolby Digital 5.1 audio?
jorlanm is offline
post #2 of 2 Old 02-06-2012, 02:50 PM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
An answer is here in your cross-post:
http://www.avsforum.com/avs-vb/showt...1#post21606371
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
Reply HTPC Gaming
