How is your audio set up? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-26-2012, 06:51 AM - Thread Starter
mudfrog's Avatar
Quoted: 25 Post(s)
I'm trying to ensure I get the best audio experience from my setup. Currently when playing games on my HTPC my receiver shows "Neo 6" which if I understand correctly is a stereo signal converted to surround. Has anyone been able to get a DD or DTS signal through HDMI from the GPU? Any tips for me to get this working correctly?
HTPC Specs:
Phenom II x4 920 -Scythe Shuriken 2
Gigabyte GA-MA785GM-US2H
4GB Kingston HyperX DDR2 1066
Zotac 560ti 1GB
1TB WD Black
2TB WD Green
Windows 7 64
Samsung Blu-Ray
Silverstone GD05
OCZ ModXStream 600w
Onkyo TX-NR509
Polk Audio Monitor II - CS2
Polk Audio Monitor II - Monitor 70 x 2
Polk Audio Monitor II - Monitor 30 x 2
BIC F12 - 12" Sub
Equipment - 60" Vizio M60-C3 - Denon AVR-2300W - Pioneer BDP-150 - HTPC, Xbox One - Sennheiser RS170 Headphones - APC C25B Power Filter
Speakers - SVS Prime Center, Bookshelves, Satellites, PB-2000
HTPC - Intel Core i3-3220, 8GB DDR3 1600, 750ti 2GB, 7TB of HDD's, LG Bluray
mudfrog is offline
post #2 of 10 Old 04-27-2012, 07:29 AM - Thread Starter
mudfrog's Avatar
Quoted: 25 Post(s)
Anybody have any insight on the proper way to get surround from PC games?
mudfrog is offline
post #3 of 10 Old 04-27-2012, 07:42 AM
MitchPope's Avatar
Quoted: 26 Post(s)
Liked: 25
Do you have a "digital out" or "Dolby Digital" or "AC3" setting or anything like that on your sound card/GPU? It may only be set to send stereo PCM as a default because it doesn't know what you are going to connect it to. There should be either an on/off to send the bitstream of the audio instead. I wish I could be more help, but I'm on a Mac so the dialog boxes won't be the same.
MitchPope is offline
post #4 of 10 Old 04-27-2012, 09:35 AM
257Tony's Avatar
HTPC Specs:
Zotac 560ti 1GB
1TB WD Black
2TB WD Green
Windows 7 64
Samsung Blu-Ray
Silverstone GD05
OCZ ModXStream 600w
Onkyo TX-NR509
BIC F12 - 12" Sub
Generally when gaming and using HDMI from the GPU you will get 5.1 PCM out. Sounds great, no need to fret over not seeing the DD or DTS light on your AVR. Just use the standard windows sound config tool to set it up, its super easy.
257Tony is offline
post #5 of 10 Old 04-27-2012, 10:20 AM
FuNkfor20's Avatar
Im not sure about GeForce cards but ATI has a setting in the video card to send audio decompressed over the HDMI.
FuNkfor20 is offline
post #6 of 10 Old 04-27-2012, 12:25 PM
krimson's Avatar
You shouldn't expect to get a DTS or DD signal. The audio device does not do dolby digital live or dts connect, so you will be getting a raw PCM signal rather then a dolby signa. This is good though, it means your audio is not being compressed to send to the receiver.
You may not be configured right on your receiver. See if there is a "Direct" mode or something along that lines and try that. It will turn off any post-processing on the audio and would hopefully get you out of Neo 6 mode.
PSN / Steam - KrimsonStudios
krimson is offline
post #7 of 10 Old 04-27-2012, 01:23 PM
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 53
I've been using crap computer speakers for gaming but now that I got a new ysp 2200 that has virtual 7.1 and truehd I'm wondering if I should get a sound card. Running mobo is gigabyte z68 up3
My theater build : Roll-In Reels Cinema (7.2.4 atmos theater)
lpnaz480 is offline
post #8 of 10 Old 04-27-2012, 06:09 PM
HeadRusch's Avatar
Quoted: 162 Post(s)
Liked: 115
DD or DTS should stream natively from content that has it, but games use discrete channels, few use DD or DTS. Over HDMI I believe your system should be sending 5.1 in its native format. I saw another poster say this, try setting your receiver to its AUTO mode for that input or cycle through to see if it has a "SOURCE DIRECT" or some other mode.
Of course, you also have to make sure Windows is set to output digitally through the HDMI port and make sure its not forcing some kind of format on its own and just passing PCM natively (make sure its not set to just stereo, etc).
Back in the day, you used to have to get a sound card that had Dolby Digital Live for on-the-fly conversion of PC game surround audio, or you had to output the 3.5mm jacks to RCA cables and run them directly into the analog 5.1 inputs on stereos to get your game surround.
Or, you just cheaped out and ran digital to digital over optical/coax and turned on Dolby Pro Logic IIx
Xbox Live / PS3 / Steam: HeadRusch1
Keeping the world safe from the evil antics of Bernie Tanaka and Mel Fujitsu since 1986
HeadRusch is offline
post #9 of 10 Old 04-28-2012, 03:14 PM
N8DOGG's Avatar
Quoted: 1111 Post(s)
Liked: 1211
I still use analog for my setup. Normally I love everything digital but I've always though analog sounded best on my PC. I'm currently using the razer Tiamat 7.1's and have to admit, they are pretty damn good! I'm also running the edifier S500's and they do a great job with my Forte 7.1.
N8DOGG is offline
post #10 of 10 Old 04-29-2012, 12:50 PM
hdtv00's Avatar
Quoted: 184 Post(s)
Liked: 108
YOu want to set pc audio in control panel to 5.1 channels or 7.1 whatever you have. Then on your onkyo like headrusch said you're in the wrong sound field. Cycle through until the onkyo says multich that's when you'll know when you have it all set right.
Marantz 7702MKII/Outlaw 7140 65" 4k Samsung KS8000
i7 4770K/16 gig 2133/970's SLI 840 PRO SSD
Paradigm Studio v3 100/570/20's/470's/2200 Sub
hdtv00 is online now
Reply HTPC Gaming
