Sound card decision - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-29-2012, 08:12 AM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 53
Didn't want to hijack another members thread so I'm starting a separate one. I just bought a new soundbar the ysp 2200 and have it connected via hdmi from my Gtx 570 to soundbar. However Gtx doesn't have as many formats as I'd like. I'm looking into getting a dedicated sound card just haven't decided yet and need to save. For the time being tho how can I get the mobo's audio to my Gtx then out to my soundbar? Is it as easy as hdmi from mobo > Gtx 570 "hdmi in" > "hdmi out" > soundbar ?
My theater build : Roll-In Reels Cinema (7.2.4 atmos theater)
lpnaz480 is offline
post #2 of 8 Old 04-29-2012, 01:45 PM
hdtv00's Avatar
Quoted: 131 Post(s)
Liked: 72
YOu lost me at sound bar...LOL.
Marantz 7702MKII/Outlaw 7140 65" 4k Samsung KS8000
i7 4770K/16 gig 2133/970's SLI 840 PRO SSD
Paradigm Studio v3 100/570/20's/2200 Sub
hdtv00 is offline
post #3 of 8 Old 04-29-2012, 03:44 PM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 53
i'm start with smaller simpler steps as my first post wordage was long and lost
i have hdmi from graphic card (gtx 570) to soundbar, for video
i have optical cable from mobo to soundbar optical for audio (mobo has formats i want)
problem is i want to only have one cable running to bar.
i'm wondering what my options are to get audio from mobo and video from graphics card with one cable running from htpc to soundbar?
can i plug an hdmi cable from mobo to graphic card, to get the supported audio i want, then run hdmi cable from the graphic card to soundbar, getting both video and audio?
lpnaz480 is offline
post #4 of 8 Old 04-29-2012, 06:09 PM
LexInVA's Avatar
Quoted: 526 Post(s)
Liked: 218
The audio from your mobo is digitally routed to the card and put out through the HDMI if you have it set up properly. A sound card is of no use to you and would not give you anything you don't already have.
LexInVA is offline
post #5 of 8 Old 04-29-2012, 11:51 PM
darklordjames's Avatar
Liked: 94
The GTX 570 spits out 8 channel PCM. The YSP-2200 accepts 8 channel PCM. You do not need a sound card, and you do not need other formats. If the concern is decoding Dolby/dts HD, the you just need to set your player to decode that in software for 8 channel PCM output.
Adding a sound are would be moving backward, and is a poor idea.
darklordjames is offline
post #6 of 8 Old 04-30-2012, 09:30 AM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 53
Thanks for the advice and direction darklord. I'll go back and look into it.
lpnaz480 is offline
post #7 of 8 Old 04-30-2012, 11:10 AM - Thread Starter
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 53
Thanks dark. I'm more clueless then I thought. Which software do I use to change the setting. Just under control panel then configure hdmi to 7.1 or is there something more specific?
lpnaz480 is offline
post #8 of 8 Old 04-30-2012, 11:12 AM
Liked: 94
That should be all you need to do to get games and multichannel audio sources to spit out 7.1 PCM over HDMI. If you want to play Dolby HD Bluray, then you'll need to change settings in your player software, though I don't know what.
Reply HTPC Gaming
