MMO style combat - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 05-14-2012, 09:33 AM - Thread Starter
sync's Avatar
I've been playing World of Warcraft. There are a lot of things I like about it. But I find the combat boring.
Most MMOs seem to have the same style of combat targeting. Is there a technical reason for this? I assume it has something to do with making hit detection a lot easier.
sync is offline
post #2 of 14 Old 05-14-2012, 10:20 AM
mekret's Avatar
Try Tera Online or Guild Wars 2 (when it comes out) for something a little different.
mekret is offline
post #3 of 14 Old 05-14-2012, 10:26 AM - Thread Starter
sync's Avatar
I was looking forward to GW2. I saw a youtube video from a beta tester that indicated it still has the same combat mechanics except it auto-targets for you. If that is true, I won't be getting it.
sync is offline
post #4 of 14 Old 05-14-2012, 10:28 AM
mekret's Avatar
Check out Tera Online?
mekret is offline
post #5 of 14 Old 05-14-2012, 10:41 AM
dlconner's Avatar
Combat in MMO's are turn based depending on the weapon item you use. Spells/skills have casting times, and auto swings delay depending on your weapon speed. It all goes back to turn based elements from RPG's, (they are MMORPG's after all). Very few break this mold. I have yet to try TERA, but hear it is a bit different as well.
dlconner is offline
post #6 of 14 Old 05-14-2012, 11:07 AM - Thread Starter
sync's Avatar
The combat looks good.
I'm not sure about the gameplay though. It still seems to be typical grinding MMO gameplay.
The thing about GW2 that interests me is that the gameplay seems dynamic.
sync is offline
post #7 of 14 Old 05-14-2012, 11:08 AM - Thread Starter
sync's Avatar
The RPGs I've played, Elder Scrolls and Diablo are not turn based.
sync is offline
post #8 of 14 Old 05-14-2012, 11:20 AM
mekret's Avatar
Want to try it?
mekret is offline
post #9 of 14 Old 05-14-2012, 04:06 PM
Threefiddie's Avatar
Quoted: 412 Post(s)
Liked: 187
yes there is a technical reason for that. old and current gen mmos were built on compensating for lag with multiple types of internet connections but yet built to still be playable in higher lag situations. Now that it is 2012 we are starting to see different combat in mmo because latency issues are much lower now in 2012 compared to 99-2004 for eq and wow like mmo combat games because we have stronger internet across the world now.
trying my luck with sony a1e after what feels like being in jail when I look at 2 lg c7's I've had. Jailbars you can see in movies and games isn't acceptable for this kind of money. LG calls it "normal" maybe sony won't with same panel.
Threefiddie is offline
post #10 of 14 Old 05-14-2012, 04:21 PM - Thread Starter
sync's Avatar
Want to try it?
Which one?
sync is offline
post #11 of 14 Old 05-14-2012, 04:31 PM
mekret's Avatar
Which one?
Tera online. I can lend you an account if you like.
mekret is offline
post #12 of 14 Old 05-14-2012, 04:35 PM - Thread Starter
sync's Avatar
Thanks for the kind offer. With Diablo coming out tomorrow I won't have time to try out any other games for a while.
sync is offline
post #13 of 14 Old 05-15-2012, 03:02 PM
formulanerd's Avatar
i'd be extremely interested in trying Tera... i'm in the same boat as the OP, and enjoying gw2 beta weekends, but they're too far apart
really interested in Tera, but not sure if I want to drop the $50... skipping D3 for now.
No trees were harmed forming this post, though many electrons were inconvenienced.
SERGEANT SERGEANT MASTER SERGEANT SHOOTER PERSON
Then:|A40|AX720|F1|K702|DT880|ES7|MS2i Now:|MS1|AD700|PC360|A30
formulanerd is offline
post #14 of 14 Old 05-15-2012, 04:50 PM
mekret's Avatar
Send me a PM if you'd like to, formulanerd.
mekret is offline
Reply HTPC Gaming
