Applying custom resolution signals on VGA using 1280x1024 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-19-2012, 10:06 PM - Thread Starter
Trogdor2010's Avatar
Hello.
I have been experiencing problems when applying custom resolution on both Nvidia Control Panel and Powerstrip. My current 1080p digital projector is having problems with the color wheel failing, so I took refuge on my older Sharp XV-Z9000U. The projector won't accept the 720p output from the computer, but I can send it as a 1280x1024 if I want 720p widescreen. I tried to apply custom resolution the same way I had with my older computers, by using a "resolution within a resolution" with powerstrip for VGA, but that does not work with my new computer very well. Since I am connected to a VGA out, GPU scaling won't work on Nvidia, nor does overscan on Nvidia. Powerstrip is a trial and error process, even I if "could" get it right, my games have a problem cooperating with it. My current set up uses a Nvidia GTX 285, and I have done this with older, vga only computers that swam well with it. I am running out of options.
Trogdor2010 is offline
Reply HTPC Gaming
