pci express question. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-09-2012, 12:40 PM - Thread Starter
mjfoster77's Avatar
Ok I want to upgrade my gpu for my gaming pc. I have a motherboard that supports pci express (two slots). The new gtx 550 ti card is pci express 2.0, can I run this card with my motherboard or would I need to upgrade that as well. I appologize if this is a dumb question, I've been out of the pc thing for awhile....
xbox live:sixsec assassin
mjfoster77 is offline
post #2 of 2 Old 07-09-2012, 01:58 PM
scorp133's Avatar
PCIe 2.0 cards should be backwards compatible with a PCIe 1.0 slot. Just make sure that its an x16 slot (as x1 and x4 slots are physically smaller and will not fit most video cards)
OIFII vet
USMC Sgt.
scorp133 is offline
Reply HTPC Gaming
