Using a 360 gamepad to activate a program - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-21-2012, 12:48 AM - Thread Starter
Trogdor2010's Avatar
In anticipation for Steam Big Picture, I was wanting to ask if I can use my gamepad (like a 360 controller) to activate a program, similarly to using your remote with a HTPC, or even using it to boot up your computer and start up menu, and go directly to Steam Big Picture by pressing the Xbox button once, and I can shut it down directly with the gamepad too (which can be done with Big Picture); basically make it plug and play. Are there any programs that can create a button command to start up a program?
Trogdor2010 is offline
post #2 of 9 Old 08-23-2012, 02:25 PM
taskman's Avatar
Quoted: 17 Post(s)
Ah, your in luck. You will find exactly what you want here: xpadder.com. I have been using it for 2 years now with an xbox controller in replacement of a regular remote for movies and emulators. You will have to buy the windows xbox controller kit though but its worth it.
taskman is offline
post #3 of 9 Old 08-23-2012, 02:33 PM
darklordjames's Avatar
Liked: 94
Xpadder is a chunky mess that requires far too much fiddling to get working.
darklordjames is offline
post #4 of 9 Old 08-23-2012, 04:11 PM
2002whitegt's Avatar
I was in a similar situation and this program was perfect
http://nirklars.wordpress.com/xboxmouse/
It makes the xbox contoller like a mouse, It's perfect, I just put the shortcut into the startup folder and it starts with windows. There's a lot of great hotkeys too.
2002whitegt is offline
post #5 of 9 Old 08-23-2012, 05:38 PM
jhoff80's Avatar
Quoted: 379 Post(s)
Liked: 334
It's really too bad that the Guide button doesn't do anything useful (in fact, now that I think about it, I haven't seen it do anything lately. I know it used to give a popup about battery status or something like that, but that hasn't done anything for me for a while). As far as I know you can't even map it in something like Xpadder.
I know I'd love to map it to launch Steam myself.
XBL/Steam: JHoff80
jhoff80 is offline
post #6 of 9 Old 08-23-2012, 06:18 PM - Thread Starter
Thanks! I just tried it, and it is pretty good, although there is an issue with the on screen keyboard not programming correctly unless I run as admin. Would have been great to use the D-pad at-least to select the keys on the on screen keyboard. I can transition from desktop to steam to something like GTA IV easily, but I found out an issue with the radio stations on the game aren't working right (driver issue).
Also isn't the center button basically the Home button? I haven't tried it out, but I'd figure someone would figure it out.
post #7 of 9 Old 08-25-2012, 10:48 AM
taskman's Avatar
Quoted: 17 Post(s)
It depends on what you want to do. I wanted the ability to load multiple profiles for anything from general use, to home theater, or all emulators that can be configured to mimic each emulated systems controller, SNES, NES, MAME, etc. It might seem like a mess but I consider it a precision tool that lets you design your own controller exactly the way you want it.
joe531 likes this.
taskman is offline
post #8 of 9 Old 08-27-2012, 08:23 AM
number1laing's Avatar
Liked: 32
Set up XBMC and you can use a controller to launch games or anything. It's basically a XBMC profile + Advanced Launcher add-on.
number1laing is offline
post #9 of 9 Old 08-28-2012, 05:21 PM
joe531's Avatar
Same. Xpadder is an essential piece of software on my HTPC. Combined with XBMC and different batch files, I can easily run emulators, older games like GTA III and newer games like Batman AC with ease.
joe531 is offline
Reply HTPC Gaming
